Some problem with product display
- archinfoto
12 years 7 months ago #149955
by archinfoto
Some problem with product display was created by archinfoto
www.infoto.tw
-- HikaShop version -- : 2.3.0 essential
-- Joomla version -- : 3.2.3
-- PHP version -- : 5.4.26
-- Browser(s) name and version -- : google chrom
How can I fix them?
- When I click any product (see pic.1), the template was not correct display.
{hikashop_social} didn't work.(see pic.2)
when I disable Hikashop Social Networks Plugin, the template still not correct display. - When I set different Characteristics with color, I choose B type to checkout(see pic.3), but the cart still pick A type.(see pic.4)
How can I fix them?
- Thank you received: 1778
12 years 7 months ago #149961
by Mohamed Thelji
Replied by Mohamed Thelji on topic Some problem with product display
I just tested it and it worked fine, so can you :
- Active the Joomla debug mode ("Administration->Global configuration->System->Debug System/Language")
- Set the "error reporting" option of the Joomla configuration to "maximum"
- Test it again so that we can see if it display an error message through your product page.
- archinfoto
12 years 7 months ago - 12 years 7 months ago #150060
by archinfoto
Replied by archinfoto on topic Some problem with product display
At product display
the error message is:
At cart display
there is no error message but with language
on the cart top
thanks your help
Warning: require_once(/home2/cpmpcomt/public_html/archinfoto/includes/application.php): failed to open stream: No such file or directory in /home2/cpmpcomt/public_html/archinfoto/components/com_jcomments/classes/plugin.php on line 59
Fatal error: require_once(): Failed opening required '/home2/cpmpcomt/public_html/archinfoto/includes/application.php' (include_path='.:/usr/php/54/usr/lib64:/usr/php/54/usr/share/pear') in /home2/cpmpcomt/public_html/archinfoto/components/com_jcomments/classes/plugin.php on line 59
At cart display
JROOT/language/zh-TW/zh-TW.com_hikashop.ini : 錯誤的行號是 2107, 2109
Strict Standards: Only variables should be assigned by reference in /home2/cpmpcomt/public_html/archinfoto/plugins/hikashoppayment/alphauserpoints/alphauserpoints.php on line 155
thanks your help
Last edit: 12 years 7 months ago by archinfoto.
- archinfoto
12 years 7 months ago #150062
by archinfoto
When I switch off "Enable comments on products " form Jcomments to No at hikashop configuration.
It become all right.
But I need to use Jcomments, do you have any suggest ?
12 years 7 months ago #150251
by Xavier
Replied by Xavier on topic Some problem with product display
Thanks to check if your version of Jcomments is up to date, and compatible with your Joomla version.
An alternative could be to use the HikaSop integrated comments system.
- archinfoto
12 years 7 months ago #150474
by archinfoto
I have checked it. Jcomments is final 3.0.0 stable.
But still not work.
But still not work.
12 years 7 months ago #150587
by Xavier
The errors are Jcomments errors, not HikaShop.
So I think that you should ask to the Jcomments team why you have these errors.
Regarding the translation, thanks to check the language file near the error line in order to see if there is no double quotes missing or something like that.
For the alphauserpoint error, it's just a strict standard, probably a "&" to remove at this line, nothing important, that can be ignored for the moment.
