Any product view problem
12 years 6 months ago #152253 by allertec
-- url of the page with the problem -- : www.alphatrainingservices.co.uk/componen...14-first-aid-at-work
-- HikaShop version -- : 2.3.0 Starter
-- Joomla version -- : 3.2.3
-- PHP version -- : 5.3
-- Browser(s) name and version -- : Firefox 28
Hello everybody,
I`m currently trying to setup any view for product page. Now in below link it`s tab view:
However tabs don`t appear properly. I don`t even know why. In top of this product page left part and right part should be in the same row. I`ve tried to fixed this setting width for Left part, for right part and I failed. It`s not showing properly in the same row. This doesn`t work even for reversed or DIV`s part.
Question: Does any one knows how to resolve problem with tabs and that row?
12 years 6 months ago #152278 by Xavier
Replied by Xavier on topic Any product view problem
The left part and right one are on the same row so I think that you have solved this issue.
Regarding the tabs, they seem to be working fine too, but the lists inside a tab.
Thanks to edit the hikashop frontend css file via the menu Configuration > Display > CSS and replace:
#hikashop_tabs_div li
By:
.hikashop_tabs_div_li
12 years 6 months ago #152464 by allertec
Replied by allertec on topic Any product view problem
Hi Xavier,
Yes, I ve done it. Sorr that I didn`t close the topic.
Thank you for help.
Time to create page: 0.250 seconds
