Disable hikashop_product_right_part for quests
12 years 5 months ago #153997 by hennysmafter
-- Joomla version -- : 3.2.3
-- PHP version -- : 5.3 & 5.4
-- Browser(s) name and version -- : All big ones
Dear Hikashop developers and users,
I have a question and I have looked everywhere on the forum and documentation but cant find it or i use the wrong words by search.
How to disable everything on the right side of a product page. The ID for the div is hikashop_product_right_part. This part needs to be disabled for guests. So that only logged in customers can see this.
Thanks for helping.
12 years 5 months ago #154002 by Mohamed Thelji
The solution will probably be to edit the code of the "show_default" file of the "product" view of your front-end template through "Hikashop->Display->Views". But some developer skills will be required.
12 years 5 months ago #154121 by hennysmafter
Dear Mohamed Thelji, I am going to look into what you just said. It sounds great. In the meantime I found another solution on stackoverflow and that is to create 2 custom html modules and inside I added display none and display inline. But that is an ugly hack so I am going to try your suggestion. Thank you.
12 years 5 months ago #154265 by Xavier
Time to create page: 0.238 seconds
