Tab and ">>" sign problem when using bootstrap
12 years 5 months ago #155992 by boerdonk
I have a bullet problem on the product page. Extra tab and ">>" is visible when bootstrap is on. Take al look at my test site (bootstrap is on now) : www.test.vanboerdonk.nl/index.php/nishikigoi .
Joomla 2.5
Artisteer Template
Latest version HikaShop
12 years 5 months ago #156018 by Mohamed Thelji
I just checked your website and didn't saw any ">>", did you solved your issue ?
Also, note that the solution will probably be to use some CSS code to hide the ">>" text : www.hikashop.com/support/documentation/1...ize-the-display.html
12 years 5 months ago #156160 by boerdonk
Was testing in the Joomla template.css and changed the content url line. This works voor the bullet but not for the extra tab (and line) problem.
Just removed the /* */ so you can see the problem.
.art-postcontent ul>li:before, .art-post ul>li:before, .art-textblock ul>li:before
/* content: url('../images/postbullets.png');*/
margin-right: 6px;
bottom: 2px;
position: relative;
display: inline-block;
vertical-align: middle;
font-size: 0;
line-height: 0;
Thanks for your fast reaction.
12 years 5 months ago #156180 by nicolas
Try to add such CSS:
.hikashop_products ul>li:before, .hikashop_products ul>li:before, .hikashop_products ul>li:before { content: none !important; }
The following user(s) said Thank You: SarahW, boerdonk
12 years 5 months ago #156225 by boerdonk
This works fine. Look at the result on www.koiselect.nl
Time to create page: 0.242 seconds
