URL issue and product picture display issue
12 years 6 months ago #156625
by everfree
URL issue and product picture display issue was created by everfree
i have 2 question
1) as you can see this URL dronerc.ca/index.php/hikashop-menu-for-c...ve-video-transmitter
how can i change part of the word in the URL "hikashop-menu-for-categories-listing" to something else ?
2) as you can see in this product link dronerc.ca/index.php/hikashop-menu-for-c...ve-video-transmitter , just wonder how can i make the product picture align to Left and bigger size the product picture ? or at least bigger size the product picture ?
Please advise. thx so much
i have 2 question
12 years 6 months ago #156666
by lousyfool
Replied by lousyfool on topic URL issue and product picture display issue
This might not be the answer you expect, but it's well-meant advice from another user:
First, you have a much bigger problem: click on "add to cart" and see what I mean - you're out of memory. If you can't fix it yourself, talk to your web host.
Re. your 2 questions, it can easily be solved by consulting the documentation ("customising" is the keyword), and/or by using the search here in the forum - it's been discussed several times.
Cheers and good luck!
12 years 6 months ago #156670
by everfree
Replied by everfree on topic URL issue and product picture display issue
what should i ask the hosting to help? which thing they need to increase the memory ?
12 years 6 months ago #156671
by lousyfool
It's the memory setting in the php.ini file, which a user has often enough no access to on shared host servers. Eventually you can cheat your way out by modding the .htaccess file, too.
Google is your friend: take the common portion of the error message and do some (re)search. Learning never hurts!
12 years 6 months ago #156672
by everfree
so how many is enough memory ? i need to tell the support ask them to incrase it
for the question one , are you mean can find it in here www.hikashop.com/support/documentation.html#hikashopdoc in HikaShop documentation --> Customization section ? then search Product picture ?
12 years 6 months ago #156673
by lousyfool
Memory:
Can it ever be enough?! Anyway, it depends on how "demanding" your site is. But IMHO (and it can only be humble) 128MB should get you quite far, if not through it forever.
For Q1, which isn't about product pictures, simply put "hikashop-menu-for-categories-listing" into the search here in the forum. There should be answers coming up. However, reading docs, how-to's and FAQ's will absolutely not hurt, either.
Q2 is about customisation via views and CSS. And yes, there is a lot on that in the docs you're linking to. So much that there's really no point in repeating it here. Ok, it won't teach you the basics of PHP and CSS, but you do own an Interweb, right?
You can tell that you're very welcome here with specific questions. Take my user's word for it if you can't tell from browsing the forums: this is the very best support in Joomlaworld. Nope, I'm not part of the machine.
12 years 6 months ago #156640
Replied by nicolas on topic URL issue and product picture display issue
1. That's the alias of your menu item. Edit your menu item via the menu manager of Joomla and change its alias if you want something else.
2. You can change the size of the main image thanks to the options "product page image width/height" of the HikaShop configuration.
