Product Layout design - please help
12 years 5 months ago #158061 by wild
-- url of the page with the problem -- : www.a-cutabove.co.uk
-- HikaShop version -- : 2.2.3 starter
-- Joomla version -- : 3.2.2
-- PHP version -- : 5.4.28
Hi - I have attached my product page as it stands now - the template is Favthemes Favourite.
I am struggling to make this (and other) product and category description, heading, pricing, options etc text and wording into an attractive design. The product font heading, for example (attached), is too large. How do I find the correct files to edit. I do have Firebug but still cant find the right files to edit...Please Help... and thanks
12 years 5 months ago #158066 by Mohamed Thelji
The best solution will be to use some CSS code like :
span#hikashop_product_name_main { font-size: 18px; }
Also, reading that documentation will probably help you : www.hikashop.com/support/documentation/1...the-display.html#css
12 years 5 months ago #158191 by wild
hi again and thanks mohamed and other capable hikashopers- this is my first attempt at hikashop.
I am from a design background rather than the coding.
I am going to spend a couple of hours learning Firebug properly and then hopefully be able to find the correct code to edit.
Is it possible to create a table and include the various parts of the product/category descriptions, options and prices etc into the table to make it more attractive ?
12 years 5 months ago #158233 by Jerome
I want to say that almost everything is possible using the view overrides.
Because you can change the HTML (php) used by HikaShop for the product pages, listing, etc ; you can change the design and display nearly whatever you want to.
But it requires some time and some design skills.
12 years 5 months ago #158275 by wild
hi again jerome and mohamed - yes the code I am looking for to start with (sourced using firebug) is:
<div id="hikashop_product_top_part" class="hikashop_product_top_part">
<h1>
<span id="hikashop_product_name_main" class="hikashop_product_name_main"> Womens Dress 1 </span>
<span id="hikashop_product_code_main" class="hikashop_product_code_main"> Womens_Dress_1_2 </span>
</h1>
</div>
BUT when I go into Hikashop Display Views - i cannot find the correct file to edit? A simple task just to adjust <h1> to <h3>?
Do you know which file it would be? Thanks
12 years 5 months ago #158378 by Xavier
To change h1 to h3 in a product page, the view to edit is "product / show_default".
The following user(s) said Thank You: wild
