Category and subcategory display problem
- siccreations
12 years 5 months ago #160646
by siccreations
Category and subcategory display problem was created by siccreations
I'm using JSN Glass Pro with HikaShop. I had everything set and working, but I just noticed a template problem that was not there before. I haven't changed anything, so I'm not sure what happened.
The issue is with the pages that show my product categories and subcategories.
See siccreations.org/index.php/2014-03-31-18-29-07
and siccreations.org/index.php/2014-03-31-18...y/17-hair-clips-pins
Each Category used to be in a square container, showing 3 boxes per row. Now it is stretching the container all the way across the row with only 1 category per row.
How can I fix this?
How can I fix this?
12 years 5 months ago #160720
by lousyfool
Replied by lousyfool on topic Category and subcategory display problem
In the HikaShop backend, go to Display -> Content menus and find the menu with ID 149 in the list. Open it and check what the "Number of columns" is set to. I bet it's "1". Set to "3", save, and all should be good.
- siccreations
12 years 5 months ago #160809
by siccreations
Replied by siccreations on topic Category and subcategory display problem
- siccreations
12 years 5 months ago #160812
by siccreations
Solved! I added in a 3 in the number of columns box under Display -> Content menus-> Product categories under "Details" as it was blank. Thank you very much for your help lousyfool
