Product images is not showed
12 years 4 months ago - 12 years 4 months ago #160691 by fuxo
-- url of the page with the problem -- : kikagarden.sk/index.php?option=com_hikas...=zelenina&Itemid=242
-- HikaShop version -- : HikaShop Starter 2.3.1,
-- Joomla version -- : 2.5.14
-- PHP version -- : 5.3.21
Hi guys,
i have problem with showing product images. I dont know why, but in category listing is images showed normally, but when i open specific product, image is not showed.
I have categories, where all works fine and product images are showed, but in new categories i don't know turn on show this product images.
product images showed: kikagarden.sk/index.php?option=com_hikas...ery-kliny&Itemid=126
product images not showed: kikagarden.sk/index.php?option=com_hikas...=zelenina&Itemid=242
and i don't see different of setting in theese categories.
Please, have you any ideas, whats wrong?
Thanks for any answer.
fuxo
Last edit: 12 years 4 months ago by fuxo.
12 years 4 months ago #160711 by Mohamed Thelji
Hello Fuxo,
Can you try to delete and add again the image of one of the product of your "Zelina" category and test it again ?
12 years 4 months ago #160833 by fuxo
Replied by fuxo on topic Product images is not showed
Hi Mohamed,
thank you for answer.
Hmm, i was try complete delete image (from server via FTP too) with name "Artičoka". Thumbnails was created correct, in category list are images showed normally, but in product page is image not shown again
Absolutely i don't know, where is problem.
Can i send admin access to view admin options?
Thank you.
fuxo
12 years 4 months ago #160864 by nicolas
It's either coming from the options of the "Images" section of the configuration or from the fact that the thumbnails folder (media/com_hikashop/upload/thumbnails/) is not writable.
Check that you provided both a width and height in the image height/width on product page option of the configuration.
12 years 4 months ago - 12 years 4 months ago #160960 by fuxo
Hi nicolas,
Hmm, i don't know... Former created products have normally showed images: kikagarden.sk/index.php?option=com_hikas...ery-kliny&Itemid=126
but now, is field for product image empty. I don't know about any changes in options (but client have admin rights and maybe change configuration (probably not)).
I attach configuration for image and for product.
Writable right is probably okay, in folder media/com_hikashop/upload is really a lot of directories with several images (image3).
If you need, i will send admin access to you.
Thanks for any ideas, client is a little nervous...
12 years 4 months ago #160966 by fuxo
UAA: IT WORKS!
In filezilla is see, that directories was have really wrong rights (750). When i change rights to 755, product images is showed correct.
I know, this is really amateur problem, but i use Akeeba Admin Tools to automatic CHMOD settings and i don't check, whatever really.
Really thanks for you willingness.
Have a nice day.
12 years 4 months ago #160973 by fuxo
OMG, not works:
When i upload any random image from my HDD, image is showed normally - screen 1 + 2
But when upload specific image (image 3), in field for product image ist empty :S (screen 3)
Between uploads images i don't change any options, only click on save button:
For example:
Open a product in backend and upload random image from HDD => click on SAVE = image is showed.
I delete this image and upload specific image (attechment 3) and click on SAVE = image is not showed.
I absolutly don't understand why.
Have you any ideas? (all uploaded images is JPG format)
12 years 4 months ago #160985 by nicolas
Then maybe it's the name of the file ?
The forum changed it so I don't know what you had for the name of your image.
When I try on my end, your image displays fine after I upload it.
12 years 4 months ago - 12 years 4 months ago #161110 by fuxo
i was try your recommendation, but issues still proceed :((
I attach screen capture from my webshop: kikagarden.sk/image_WTF.mp4
In video i try upload random JPG file from my HDD and refresh webshop - image is shown.
When upload image "h1cc9c5e.jpg" - downloaded from my former post, image field is still empty.
Absolutely don't understand, what happened... :-/
Thanks for any ideas for this problem.
12 years 4 months ago #161366 by fuxo
Hi guys, no ideas?
12 years 4 months ago #161388 by nicolas
I'm not able to reproduce the problem: take.ms/EJ4JV
The image works fine on the product page without doing anything special on my end.
Maybe it comes from your images settings ? Make sure that you specify both a width and a height in the configuration for the product page image.
12 years 4 months ago - 12 years 4 months ago #161560 by fuxo
Hmm, i was try migrate my webshop to other server and when open a "problematic" product, i see this errors:
kashima.sk/domains/garden.sk/index.php?o...esky-rany&Itemid=126
Warning: imagecreatetruecolor() [function.imagecreatetruecolor]: Invalid image dimensions in /data/web/virtuals/41953/virtual/www/domains/garden.sk/administrator/components/com_hikashop/helpers/image.php on line 454 Warning: imagecolorallocatealpha() expects parameter 1 to be resource, boolean given in /data/web/virtuals/41953/virtual/www/domains/garden.sk/administrator/components/com_hikashop/helpers/image.php on line 568 Warning: imagefill() expects parameter 1 to be resource, boolean given in /data/web/virtuals/41953/virtual/www/domains/garden.sk/administrator/components/com_hikashop/helpers/image.php on line 470 Warning: imageantialias() expects parameter 1 to be resource, boolean given in /data/web/virtuals/41953/virtual/www/domains/garden.sk/administrator/components/com_hikashop/helpers/image.php on line 474 Warning: imagecopyresampled() expects parameter 1 to be resource, boolean given in /data/web/virtuals/41953/virtual/www/domains/garden.sk/administrator/components/com_hikashop/helpers/image.php on line 490 Warning: imagecreatetruecolor() [function.imagecreatetruecolor]: Invalid image dimensions in /data/web/virtuals/41953/virtual/www/domains/garden.sk/administrator/components/com_hikashop/helpers/image.php on line 454 Warning: imagecolorallocatealpha() expects parameter 1 to be resource, boolean given in /data/web/virtuals/41953/virtual/www/domains/garden.sk/administrator/components/com_hikashop/helpers/image.php on line 568 Warning: imagefill() expects parameter 1 to be resource, boolean given in /data/web/virtuals/41953/virtual/www/domains/garden.sk/administrator/components/com_hikashop/helpers/image.php on line 470 Warning: imageantialias() expects parameter 1 to be resource, boolean given in /data/web/virtuals/41953/virtual/www/domains/garden.sk/administrator/components/com_hikashop/helpers/image.php on line 474 Warning: imagecopyresampled() expects parameter 1 to be resource, boolean given in /data/web/virtuals/41953/virtual/www/domains/garden.sk/administrator/components/com_hikashop/helpers/image.php on line 490 Warning: imagecreatetruecolor() [function.imagecreatetruecolor]: Invalid image dimensions in /data/web/virtuals/41953/virtual/www/domains/garden.sk/administrator/components/com_hikashop/helpers/image.php on line 454 Warning: imagecolorallocatealpha() expects parameter 1 to be resource, boolean given in /data/web/virtuals/41953/virtual/www/domains/garden.sk/administrator/components/com_hikashop/helpers/image.php on line 568 Warning: imagefill() expects parameter 1 to be resource, boolean given in /data/web/virtuals/41953/virtual/www/domains/garden.sk/administrator/components/com_hikashop/helpers/image.php on line 470 Warning: imageantialias() expects parameter 1 to be resource, boolean given in /data/web/virtuals/41953/virtual/www/domains/garden.sk/administrator/components/com_hikashop/helpers/image.php on line 474 Warning: imagecopyresampled() expects parameter 1 to be resource, boolean given in /data/web/virtuals/41953/virtual/www/domains/garden.sk/administrator/components/com_hikashop/helpers/image.php on line 490
12 years 3 months ago #162479 by Mohamed Thelji
Sorry for the late reply, can you tell me how did you proceed to migrate your shop to another server ?
Time to create page: 0.433 seconds
