categories menu problem
12 years 5 months ago - 12 years 5 months ago #161531 by mirkozax
-- url of the page with the problem -- : www.cartashop.com/militare/
-- HikaShop version -- : 1.5.7
-- Joomla version -- : 1.5.26
Hi, I created the right categories menu, but now there is a menù with many problem like you can see, how can fixed it? I have custom File CSS frontend
thanks
Last edit: 12 years 5 months ago by mirkozax.
12 years 4 months ago #161543 by Mohamed Thelji
Using some CSS code will do probably do the job, so reading that documentation will help you : www.hikashop.com/support/documentation/1...ize-the-display.html
12 years 4 months ago #161875 by mirkozax
Replied by mirkozax on topic categories menu problem
Thanks, but the problem is which CSS code I need using, and why there are more than one green arrows per category in the right menu ?
12 years 4 months ago #161892 by Xavier
Replied by Xavier on topic categories menu problem
As the menu seems to be no more published we can't give the css properties.
But reading the given tutorial should really help you for such customizations.
Everything to know is inside this tuto.
12 years 4 months ago #163795 by mirkozax
You have a PM
12 years 4 months ago #163797 by Xavier
Actually, I don't have PM.
But have you tried to follow the tutorial given bu Mohamed ? It give all the informations to edit the layout.
It is really just css rules which needs to be applied.
ps: we don't support customizations, but bugs, configs, etc. :)
