Problems displaying product images in category.
12 years 4 months ago #162001 by sashco
Simply put: this is probably my problem, and I just can't figure it out, but here goes:
I create a product, and a category. I link the category in the main menu of joomla. Everything works great, but there is no image in the category page (I want thumbnails for products).
12 years 4 months ago #162040 by nicolas
Please provide a link to the page so that we can see what you did and analyze the HTML.
12 years 4 months ago #162435 by nicolas
As far as I can see, that's because you changed the "item box layout" option of your products listing to a layout without the image.
Go in the menu Display->Content modules, edit your products listing module (id 719) and set the item box layout option to "image and title" and you should then see the images.
12 years 4 months ago #162512 by sashco
Nicolas,
That is what it is set to, and I still do not see any images. I have not messed with defaults of anything, I just installed it and started adding products. It is not showing the images for the products in the category.
12 years 4 months ago #162533 by nicolas
Then it means that you turned off the "thumbnail" option of the configuration so that HikaShop doesn't generate thumbnails for images and thus the image is only on the product page, in full size.
The following user(s) said Thank You: sashco
12 years 4 months ago #162646 by sashco
That fixed the issue. I never disabled that, but I am glad it's fixed now.
