- Thank you received: 2
Popup for adding products to cart doesn't show up
12 years 3 months ago #165180
by praes
Popup for adding products to cart doesn't show up was created by praes
mywebsite.com/mypage
-- HikaShop version -- : 2.3.2 Business
-- Joomla version -- : 3.3.1
-- PHP version -- : 5.4.30
-- Browser(s) name and version -- : All popular browsers (OS X)
The popup/lightbox doesn't show up after adding products to the cart. At the same time a couple of things happen:
Other lightboxes also don't work (for example selecting an address at checkout).
Any help is appreciated!
Thanks, Jelger
- The cart is updated successfully, so that's ok
- There's no lightbox visible
- Scrolling down the site doesn't work anymore
- Console shows an error: Uncaught TypeError: Cannot read property 'x' of undefined - modal.js
Thanks, Jelger
- Thank you received: 1778
12 years 3 months ago #165213
by Mohamed Thelji
Replied by Mohamed Thelji on topic Popup for adding products to cart doesn't show up
I just tested it on my end and it's working fine, your issue is probably coming from your JavaScript error, can you give us link toyour website so that we can directly test it ?
12 years 3 months ago - 12 years 3 months ago #165268
by praes
Replied by praes on topic Popup for adding products to cart doesn't show up
Of course. Have sent you a DM with credentials because my site is currently hidden from the public.
Regards, Jelger
Regards, Jelger
Last edit: 12 years 3 months ago by praes.
12 years 3 months ago #165269
by Mohamed Thelji
Can you test it with one of the Joomla default templates ?
