Product description not showing
12 years 2 months ago #166320 by spidergraham
-- url of the page with the problem -- : www.spidergraham.com
-- Joomla version -- : 3.3.1
-- Browser(s) name and version -- : Firefox 30.0
Hi Folks:
I'm definitely a Hikashop newbie but trying something that I hoped would be fairly straight forward. I have 4 products that I'm displaying in a table format. The name of the products shows (in this case they are workshops) but I had expected the product description to also show up in the product list. It appears just fine when the product is clicked on but I would really like to have a brief product description appear below each of the products names?
As far as I can tell I have the toggles set correctly but I'm getting no love. Any thoughts of what I'm doing wrong?
Spider
12 years 2 months ago #166364 by nicolas
There is no option to add the description on the table listing.
You'll need to add such code in the file "listing_table" of the view "product" via the menu Display>Views:
<?php echo echo $this->row->product_description; ?>
For example, you can add it after:
<?php if(!empty($this->row->extraData->afterProductName)) { echo implode("\r\n",$this->row->extraData->afterProductName); } ?>
if you want it after the product name.
