Duplicate Products
12 years 2 months ago #168262
by DawnB
Duplicate Products was created by DawnB
Can't determine the answer to an issue we're having on a web site using Hikashop. It appears that the products are listed twice, with the second time being in reverse order. I have found another question addressing this on the forum, however, it appears to have something to do with menus and "associated modules", but when I open the menu, it indicates that there are no associated modules enabled so I'm perplexed. Specifically the css is calling out hikashop_submodules class and and hikashop_modules_115 class. For the life of me, I can't figure out how to turn off this second row of identical products.
No modules enabled in the modules manager.
Thank you.
Thank you.
12 years 2 months ago #168274
by Xavier
Replied by Xavier on topic Duplicate Products
You maybe just have to disable the module 115. It is potentially a module assigned to many menus on your website.
12 years 2 months ago #168367
by DawnB
Replied by DawnB on topic Duplicate Products
That module is not assigned to any pages or published.
Thx.
Thx.
12 years 2 months ago #168372
by Jerome
Replied by Jerome on topic Duplicate Products
Even if the module is not published, it can be assigned with an HikaShop menu or an HikaShop option.
If you edit your menu in "Hikashop > Display > Content menu", you should see the associated modules for this menu.
And it is the place where you should remove the module 115 ; because even if the module is unpublished, if you associate it with a menu, HikaShop will ask Joomla to display it.
12 years 2 months ago #168525
by DawnB
Thank you.
Time to create page: 0.223 seconds
