Insert custom fields in table display products
12 years 2 months ago #170504 by gioxd
-- url of the page with the problem -- : www.laputea.com
-- Joomla version -- : 3.2
I would like to insert custom fields in the table to display the products, but do not know how you do it. I tried to put this code <?php echo $this->row->NAME_FIELD; ?> in product / listing_img.php
But in front end I see only the number (the value) and not the name of the field. How do I display the name of the custom field?
Thank You!
12 years 2 months ago #170506 by Xavier
You can use this code:
<?php echo 'Name Field: '.$this->row->NAME_FIELD; ?>
12 years 2 months ago #172798 by gioxd
Sorry, don't work. I insert the code, maybe we can find a solution :)
<?php /** * @package HikaShop for Joomla! * @version 2.3.2 * @author hikashop.com * @copyright (C) 2010-2014 HIKARI SOFTWARE. All rights reserved. * @license GNU/GPLv3 http://www.gnu.org/licenses/gpl-3.0.html */ defined('_JEXEC') or die('Restricted access'); ?><?php $link = hikashop_contentLink('product&task=show&cid='.$this->row->product_id.'&name='.$this->row->alias.$this->itemid.$this->category_pathway,$this->row); if(!empty($this->row->extraData->top)) { echo implode("\r\n",$this->row->extraData->top); } ?> <!-- PRODUCT IMG --> <div style="height:<?php echo $this->image->main_thumbnail_y;?>px;text-align:center;clear:both;" class="hikashop_product_image"> <div style="position:relative;text-align:center;clear:both;width:<?php echo $this->image->main_thumbnail_x;?>px;margin: auto;" class="hikashop_product_image_subdiv"> <?php if($this->params->get('link_to_product_page',1)){ ?> <a href="<?php echo $link;?>" title="<?php echo $this->escape($this->row->product_name); ?>"> <?php } $image_options = array('default' => true,'forcesize'=>$this->config->get('image_force_size',true),'scale'=>$this->config->get('image_scale_mode','inside')); $img = $this->image->getThumbnail(@$this->row->file_path, array('width' => $this->image->main_thumbnail_x, 'height' => $this->image->main_thumbnail_y), $image_options); if($img->success) { echo '<img class="hikashop_product_listing_image" title="'.$this->escape(@$this->row->file_description).'" alt="'.$this->escape(@$this->row->file_name).'" src="'.$img->url.'"/>'; } $main_thumb_x = $this->image->main_thumbnail_x; $main_thumb_y = $this->image->main_thumbnail_y; $horizontal = '0'; $vertical = '0'; if($this->params->get('display_badges',1)){ $this->classbadge->placeBadges($this->image, $this->row->badges, $vertical, $horizontal); } $this->image->main_thumbnail_x = $main_thumb_x; $this->image->main_thumbnail_y = $main_thumb_y; if($this->params->get('link_to_product_page',1)){ ?> </a> <?php } ?> </div> </div> <!-- EO PRODUCT IMG --> <!-- PRODUCT PRICE --> <?php if($this->params->get('show_price','-1')=='-1'){ $config =& hikashop_config(); $this->params->set('show_price',$config->get('show_price')); } if($this->params->get('show_price')){ $this->setLayout('listing_price'); echo $this->loadTemplate(); } ?> <!-- EO PRODUCT PRICE --> <!-- PRODUCT VOTE --> <?php if($this->params->get('show_vote_product')){ $this->setLayout('listing_vote'); echo $this->loadTemplate(); } ?> <!-- EO PRODUCT VOTE --> <!-- PRODUCT CUSTOM --> <?php echo 'materialeprincipale: '.$this->row->materialeprincipale; ?> <!-- EO PRODUCT CUSTOM --> <!-- ADD TO CART BUTTON AREA --> <?php if($this->params->get('add_to_cart') || $this->params->get('add_to_wishlist')){ ?><form action="<?php echo hikashop_completeLink('product&task=updatecart'); ?>" method="post" name="hikashop_product_form_<?php echo $this->row->product_id.'_'.$this->params->get('main_div_name'); ?>"><?php $this->ajax=''; if(!$this->config->get('ajax_add_to_cart',0)){ $this->ajax = 'return hikashopModifyQuantity(\''.$this->row->product_id.'\',field,1,\'hikashop_product_form_'.$this->row->product_id.'_'.$this->params->get('main_div_name').'\',\'cart\');'; } $this->setLayout('quantity'); echo $this->loadTemplate(); if(!empty($this->ajax) && $this->config->get('redirect_url_after_add_cart','stay_if_cart')=='ask_user'){ ?> <input type="hidden" name="popup" value="1"/> <?php } ?> <input type="hidden" name="product_id" value="<?php echo $this->row->product_id; ?>" /> <input type="hidden" name="add" value="1"/> <input type="hidden" name="ctrl" value="product"/> <input type="hidden" name="task" value="updatecart"/> <input type="hidden" name="return_url" value="<?php echo urlencode(base64_encode(urldecode($this->redirect_url)));?>"/> </form><?php } ?> <!-- EO ADD TO CART BUTTON AREA --> <!-- COMPARISON AREA --> <?php if(JRequest::getVar('hikashop_front_end_main',0) && JRequest::getVar('task')=='listing' && $this->params->get('show_compare')) { ?> <br/><?php if( $this->params->get('show_compare') == 1 ) { $js = 'setToCompareList('.$this->row->product_id.',\''.$this->escape($this->row->product_name).'\',this); return false;'; echo $this->cart->displayButton(JText::_('ADD_TO_COMPARE_LIST'),'compare',$this->params,$link,$js,'',0,1,'hikashop_compare_button'); } else { ?> <input type="checkbox" class="hikashop_compare_checkbox" id="hikashop_listing_chk_<?php echo $this->row->product_id;?>" onchange="setToCompareList(<?php echo $this->row->product_id;?>,'<?php echo $this->escape($this->row->product_name); ?>',this);"><label for="hikashop_listing_chk_<?php echo $this->row->product_id;?>"><?php echo JText::_('ADD_TO_COMPARE_LIST'); ?></label> <?php } } ?> <!-- EO COMPARISON AREA --> <?php if(!empty($this->row->extraData->bottom)) { echo implode("\r\n",$this->row->extraData->bottom); } ?>
12 years 2 months ago #172837 by Xavier
I checked the code and that should work.
It's not in a if condition, so it must be displayed somewhere, unless you edited the view in the wrong template, or you have cache enabled.
12 years 2 months ago #173033 by gioxd
Ok, it work. But i visualize the number of field custom, not the name.
Is possible see the custom field name and not the value?
12 years 2 months ago #173048 by Xavier
Is that coming from a dropdown ?
I had not understood your real need.
You have to use the code:
<?php $fieldclass = hikashop_get('class.field'); $myField = $fieldclass->get('32'); echo $myField->field_value['3']->value; ?>
Where you have to replace "32" by the id of you custom field, you can find it via the Display > Custom fields menu in the backend.
12 years 2 months ago #173278 by gioxd
Simply I need to display the title of the custom field, but it appears only the value. In the screenshot you see how I set the custom fields.
Even with the code you gave me shows only the number (value) and not the title.
Maybe I'm wrong something?
12 years 1 month ago #173282 by Xavier
I tested the code on my end and it was working fine, thanks to try this code:
<?php $fieldclass = hikashop_get('class.field'); $myField = $fieldclass->get('19'); if(isset($this->row->materialeprincipale)) echo $myField->field_value[$this->row->materialeprincipale]->value; ?>
The following user(s) said Thank You: gioxd
12 years 1 month ago #173418 by gioxd
Perfect! Now it work!
Thank You!
