- Thank you received: 1
Associate product-listing module on sub-categroy
12 years 2 months ago - 12 years 2 months ago #170971
by Kuro
Associate product-listing module on sub-categroy was created by Kuro
-- Joomla version -- : 3.3.0
I am not able to add an other associated module on a sub-level (category level 2):
- Category listing A1 (level 1) // Associate product listing modul A1A1
-- Category listing A2 (level 2) // Associate product listing modul A2A2
-- Category listing A3 (level 3) // Associate product listing modul A3A3
- Category listing B1 (level 1) // Associate product listing modul B1B1
-- Category listing B2 (level 2) // Associate product listing modul B2B2
An example:
How is it possible to set other associated moduls at different category levels?
An example:
| -Category Cars | ||
| -Category Volkswagen recommendations (associated modul) | ||
| -Category Golf Best in class (associated modul) | ||
| -Category Polo Best in class (associated modul) |
Last edit: 12 years 2 months ago by Kuro.
12 years 2 months ago #171192
Replied by nicolas on topic Associate product-listing module on sub-categroy
That's not how the system works normally.
You have one category listing menu, with one products listing associated module.
The module will then display the products of the current category automatically if the "Synchronize with currently displayed item when possible" option of the module is turned on.
So normally you should not need more than one associated products module for one categories listing menu.
12 years 2 months ago #171205
by Kuro
Replied by Kuro on topic Associate product-listing module on sub-categroy
yes I know! But that is the requirement. Do you have an idea how to built that with customizing Hikashop?
12 years 2 months ago #171301
How about setting all your products listing associated modules in the same "bottom" position of your template and then using Advanced Modules Manager to restrict the display of the module to a specific category for each one ?
extensions.joomla.org/extensions/style-a...les-management/10307
