Related products module not showing up
12 years 1 month ago #172263 by ogosense
-- Joomla version -- : 3.3.3
-- PHP version -- : 5.3.28
-- Browser(s) name and version -- : Mozilla Firefox 31.0
Hi guys,
I have a problem with related products module not showing up on the product page, for any of the products.
I followed Hikashop documentation on how to set this up but it just doesn't work.
I also attached screenshots of hikashop config page , and hikashop module config page.
Please help!
Thanks,
Dushan
12 years 1 month ago #172266 by Xavier
As every Joomla modules, you have to assign it to the Joomla menus.
To have it on the product page, the module must be assigned to the menu used to reach that product page.
If you want the module only on product pages but not on listings, then you will need "advanced module manager".
12 years 1 month ago #172550 by ogosense
Xavier,
Module is assigned to all Joomla menus but still doesn't work.
Also, what do you mean when you say "advanced module manager''?
Thanks,
Dushan
12 years 1 month ago #172552 by Jerome
If you change the kind of "content on product", does the module show up (like "in the same categories") ?
Does your problem right have related product in his configuration ?
In which position is your module ?
12 years 1 month ago #172681 by ogosense
Jerome,
I'm sorry, but I don't understand what do you mean. Can you,please, re-phrase questions 1 and 2?
I didn't assign any position to the module.
Thanks,
Dushan
12 years 1 month ago #175683 by Mohamed Thelji
Hello Dushan,
Sorry for the late reply, to be sure, did you correctly followed each step of the documentation to make your related product display through your product page ?
How to display your related products below your products:
1. Create a new module of the type "HikaShop content module" via the joomla modules manager and leave it unpublished in the joomla options of the module.
2. In the HikaShop options of the module (there is a link to them on the right of the module's joomla options screen), make sure that the "Type of content" option is set to "product" and that the option "Content on product page" is set to "Related products".
3. In the configuration of HikaShop, click on the "Select" button of the "Modules under the product page" option. Set your related module to published and click on OK. Then, save the configuration.
10 years 3 months ago #245916 by Bender
does related product module need motools library for work ?
Mohamed Thelji wrote: Hello Dushan,
10 years 3 months ago #245921 by nicolas
No, it doesn't. It will display the related products regardless.
10 years 1 month ago #250227 by jasonyon
I am having the same problem. Did anyone find a solution?
When inspecting the source, there is a line that says:
<div class="item item1" style="visibility: hidden;">
I'm sure that is not supposed to be hidden. What is causing that?
Also, when I do comment out that "hidden" in the inspector, the link for the product takes me to a bad link:
index.php/component/hikashop/product/209-ultimate-tote?Itemid=511
it should be:
index.php/bags/product/209-ultimate-tote
10 years 1 month ago - 10 years 1 month ago #250270 by Philip
Hello
Can you provide a screenshot of Related Product module and especially this red bordered part ?
=> HikaShop Options tab
=> Menu Assignment tab
A link will be usefull too.
Awaiting news from you.
Regards.
Last edit: 10 years 1 month ago by Philip.
10 years 1 month ago #250323 by jasonyon
I believe I have all of the settings correct. But feel free to look.
webarchitechsnc.com/mis2/index.php/bags/...ct/209-ultimate-tote
10 years 1 month ago - 10 years 1 month ago #250381 by Philip
Everything seems well configured, can you try to switch your template for Protostar, and see if you can see your Related module ?
If that solve your issue contact your template provider support.
10 years 1 month ago #250566 by jasonyon
It does seem like a template problem. I switched it to protostar as suggested and they show up fine.
I guess I'll reach out to them.
