Problem with price access level
11 years 11 months ago #178125 by des
A while ago I wrote about problem with back-end price for all products. Now i'm havinig problem with access levels for them. When i try to set it a white screen open, but with no options.
Any idea? Maybe some code is missig?
11 years 11 months ago #178126 by Xavier
Please set the Joomla error reporting level to "maximum", this should display an error if there is a fatal error.
Else, thanks to your browser console do you see any javascript error returned ?
11 years 11 months ago #178229 by des
Replied by des on topic Problem with price access level
I've set the Joomla error reporting but still nothing... white page.
About the browser console... i try different browsers and different pc and the result was the same...
11 years 11 months ago #178251 by Xavier
Please try to reinstall HikaShop over the current one, if it doesn't work so could you give us a backend access in order to see directly what's happening ?
You can give it via private message, please give the url of that topic in the message.
11 years 11 months ago #178483 by Jerome
If you can explain me why the HikaShop core files as been modified and why the files:
"administrator/components/com_hikashop/views/product/tmpl/price.php"
"administrator/components/com_hikashop/views/product/tmpl/priceaccess.php"
Are just empty files ; I will be happy to understand.
Please do not modify HikaShop core files ; please be sure that when you update HikaShop, you have right access to all files and that the installation is processed correctly.
I can't know if other HikaShop core files are empty ; but for the moment your backend product edition is working just with the overrides, which is not normal.
11 years 11 months ago #178520 by des
Thank you!
I have not touch anything in the files. For a while I used the free version and decided to go to business. After Install everything was fine. after a few days I started to add products and saw that there is no product prices in the back-end . I wrote in the forum and then you answer me that :
"For some reasons, the file "administrator/components/com_hikashop/views/product/tmpl/price.php" was empty instead of containing the code of the price listing on your website.
We've added the code as a template override in " /administrator/index.php?option=com_hikashop&ctrl=view&task=edit&id=1|isis|component|com_hikashop|product|price%2Ephp " and it's now working."
Until now I did not use price access level and I haven't noticed this problem.
11 years 11 months ago #178525 by Jerome
Okay.
I hope that it was the two files impacted.
When you will update HikaShop next time, please check that you have right write permission on all HikaShop files (administrator/components/com_hikashop ; components/com_hikashop ; media/com_hikashop )
The next update should restore the files correctly.
Then you will be able to check the file and if good, remove the overrides.
11 years 11 months ago #178618 by des
Thank you :)
Have a nice day.
Time to create page: 0.331 seconds
