Problem with Comments Systems
12 years 2 weeks ago #178850
by ricardo
Problem with Comments Systems was created by ricardo
-- Joomla version -- : 3.3.6
Hi, I have a problerm with the comments system. If I try to write the comment and auto publish system it's activated it's all ok, but if I deactivate the auto publish I can't moderate the comments via backend.
Thanks a lot...
Ricardo.
Thanks a lot...
Ricardo.
12 years 2 weeks ago #178857
by Jerome
Replied by Jerome on topic Problem with Comments Systems
Why can't you moderate the comments via backend ?
12 years 2 weeks ago #179047
by ricardo
Replied by ricardo on topic Problem with Comments Systems
Why? I don't knwow... if I try to check Pubblish I receive an error but don't show me wath's this error...
12 years 2 weeks ago #179050
by Jerome
Okay, so you can "see" them but not publish them.
Would it be possible to have more details in general and more details about the error thanks to your PHP error log ?
Or maybe by setting the "error reporting" to "maximum" in your Joomla global configuration.
12 years 2 weeks ago #179115
by ricardo
Hi Jerome,
I need this error in for position of the database:
id select_type table type possible_keys key key_len ref rows Extra
1 SIMPLE chew_hikashop_product system PRIMARY NON E' POSSIBILE UTILIZZARE ALCUN INDICE NULL NULL 1
But I don't find the parameter "Full" for the debug... Where I find the PHP error log?
Thanks...
Thanks...
12 years 2 weeks ago #179120
by ricardo
If would you like I can give you an access to the backend...
12 years 2 weeks ago #179148
by Jerome
Yes I think it will be easier to understand the situation.
Please use the "contact us" form and provide a link to that forum thread.
12 years 2 weeks ago - 12 years 1 week ago #179333
by Xavier
Replied by Xavier on topic Problem with Comments Systems
Please edit the file "administrator/components/com_hikashop/classes/vote.php" and in the function "saveBackend()" replace:
By:
Thanks for the report, we have corrected that on our end.
if(empty($element->vote_ref_id))
$element->vote_type = $db_vote->vote_ref_id;
$element->vote_ref_id = $db_vote->vote_ref_id;
Last edit: 12 years 1 week ago by Xavier. Reason: change code order
12 years 1 week ago #179522
by ricardo
Hi, I'm sorry, but the problem persist...
12 years 1 week ago #179530
by a2zcs
Replied by a2zcs on topic Problem with Comments Systems
Maybe I'm confused. My vote.php file had:
and it didn't work.
Replaced it with:
and it does now.
and it didn't work.
Replaced it with:
and it does now.
12 years 1 week ago #179531
by ricardo
Ok, don't worry!!
Now it's solved!
Thanks a lot!!
Bye!!
Now it's solved!
Thanks a lot!!
Bye!!
12 years 1 week ago #179568
by Xavier
Yes, sorry you had to reverse the two codes, I have corrected my last topic.
