Page showing products in 1 column but set to 3
12 years 1 week ago #180038 by sbuffington
-- url of the page with the problem -- : www.toolsforpositivechange.com/index.php...es/category/12-books
-- Joomla version -- : 2.5.27
-- PHP version -- : 5.3.28
I am having an issue where the products are being displayed in a single column when I have the Number of Columns setting set to 3 and number of items to 20. I also have bootstrap design turned on. I have also noticed that no matter whether I use our old css or the default css each item shows up with the ul bullet next to it.
Any idea what I need to do to clean this up?
12 years 1 week ago #180075 by nicolas
Turn off the "use bootstrap design" option and it will display properly.
That's because your Joomla template is not compatible with bootstrap v2 which is a requirement in order to turn on that option if you want the display to work properly.
