Problems with the brreadcrumbs
11 years 11 months ago #181362 by Rossiello
-- url of the page with the problem -- : www.bellipario.it/newsite/
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.3.29
Hi and thanks for this great component
I'm using a business version and I have some problems with the breadcrumbs.
The 'url semplified is disabled' and these are the strange problems I find:
Case 1) I have the "category one" page that display all its sbu categories, clicking on subcategory link in the bread crumbs i see the correct path :home> maincategory>subcategory
Case 2) I have the "category two" page that display all its sbu categories, clicking on subcategory link in the bread crumbs i see the wrong path : home > maincategory
Case 3) Both in the two cases if from the subcategory page i click on a product listed, in the breacrmbs i never see the product name.
this is the web site url: www.bellipario.it/newsite/
if you click on link "RICORRENZE" and then on one of its subcategory link in the page you can test case one
if you click on link " IL MONDO DEI PREZIOSI" and than on one of its sub catagory link in thr page you can test the case two
if you click on link "RICORRENZE" and then on one of its subcategory link in the page and finally on one of the product listed you can test the case 3
Many thanks for all your help.
Fabrizio
11 years 11 months ago #181688 by ligfietsshop
I have the same problem as in case 3. The product name is never dispalyed. A solution would be nice to know
11 years 11 months ago #181696 by nicolas
@Rossiello:
I tried the different scenarios you're talking about on your website but each time I'm getting the correct result. Did you do something already to fix your issues ?
For example for case 3:
take.ms/WDqHX
I do see the product name in the breadcrumb.
@ligfietsshop:
As I didn't see the problem for @Rossiello and that you didn't provide a link to the shop in order to see the problem, I can't tell you anything more.
11 years 11 months ago - 11 years 11 months ago #181939 by ligfietsshop
Hello Nicolas
it is on my testsite
ligfietsshop
Last edit: 11 years 11 months ago by ligfietsshop.
11 years 11 months ago #181998 by Xavier
Please give us a screenshot of the breadcrumb module settings and the SEF url options in HikaShop > Configuration > Features.
You have to check if the option " Show Last" in the module settings is enabled.
11 years 11 months ago #182076 by ligfietsshop
Hello Xavier
The show last option is enabled. here are the screenshots
11 years 11 months ago #182204 by nicolas
That's funny because when I go to your link, I do see the product name in the breadcrumb:
take.ms/03Tdl
What's even more funny is that if I display another product from the same category, I see the product name of the first link in the breadcrumb:
take.ms/LLLIj
This means that there is some caching activated on the breadcrumb module on your website and it prevents the module from working properly.
Deactivate the caching on the module and it should work better.
11 years 11 months ago #182236 by ligfietsshop
Hello Nicolas
That fixed it thank you
