Products listing from same category
- mauriciocgpereira
11 years 10 months ago #184184
by mauriciocgpereira
Products listing from same category was created by mauriciocgpereira
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.4
Greetings,
I'm new to hikashop!
I've got several cartegories with several products in each category.
So I'd like to know if you can help me in creating a menu with a products list that shows only in the products page with products from the same category.
Thanks in advance.
Greetings,
Thanks in advance.
11 years 10 months ago #184195
Replied by nicolas on topic Products listing from same category
Go in the menu Display->Content modules and edit the module "related products" which has been precreated during the installation of HikaShop. There, change the option "content on product page" from "related products" to "in the same category".
That should then display the products in the same category at the bottom of each product page.
You can then further customize the display settings of the module in order to suits your needs.
The following user(s) said Thank You: mauriciocgpereira
