- Thank you received: 2
Split custom fields in 2 blocks
- air-diensten
11 years 10 months ago #185993
by air-diensten
Split custom fields in 2 blocks was created by air-diensten
-- HikaShop version -- : 3.3.6
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.4.36
-- Browser(s) name and version -- : na
I have created a list of custom fiels that needs to be shown on the product page.
Per default there is 1 block and i need those to split in 2 sections with both there own custom fields.
How can i establish this.
The blue section must be 1 block and also the green section must be 1 block.
11 years 10 months ago #186045
Replied by nicolas on topic Split custom fields in 2 blocks
There is no option to do that.
It will require to modify the file "show_block_custom_main" of the view "product" via the menu Display>Views and split the display of the fields into several zones. If you're not a developer, it would require you hire/find one to help you out.
