Discounts apply on many products
- htunlinnaung
11 years 9 months ago #186202
by htunlinnaung
Discounts apply on many products was created by htunlinnaung
-- Joomla version -- : 3.3.3
-- PHP version -- : 5
-- Browser(s) name and version -- : Chrom
How can i apply discounts to many products in one time.
Current option is only can set for one product.
Pls suggest me to resolve this requirement.
11 years 9 months ago #186218
by lousyfool
Replied by lousyfool on topic Discounts apply on many products
In the
commercial versions of HikaShop
, Essential or Business, you have more choices which products you want to apply a discount to - e.g. category, zone, etc.
- htunlinnaung
11 years 9 months ago #186575
by htunlinnaung
Replied by htunlinnaung on topic Discounts apply on many products
Yes currently I'm using Hikashop business 2.3.4 and one more question is I already created discount on the same category but discount isn't apply on all product of this category.How can i do this?
Pls any suggestion will be appreciated.
11 years 9 months ago #186581
by lousyfool
For anyone to be able to say more, I guess you best post screenshots:
- discount configuration
- backend product listing of the category to which the discount is applied (with filter set to "Direct sub elements")
- htunlinnaung
11 years 9 months ago - 11 years 9 months ago #186598
by htunlinnaung
Last edit: 11 years 9 months ago by htunlinnaung.
11 years 9 months ago #186603
by lousyfool
1. Well, you have set only a single product for this discount (ID 89, "Golden Opportunity"), and no category ("Category not found"). From what I understand you want, you should delete the product in this discount configuration, and select the category which contains all the products you want the discount to apply to.
2. It's obsolete now since it has become clear that you misconfigured the discount, but I had asked for the backend product listing. Anyway, no need anymore.
P.S.: You're based in Singapore? Me too.
- htunlinnaung
11 years 9 months ago #186626
by htunlinnaung
Discount price is not show whether i set product or category.
But some product is correctly show discount price which i applied in backend.
You can check live site online which i applied discounted product but not show discount price there.
Here is link -> www.hofs88.com/index.php/shop/relationsh...9-golden-opportunity
But some product are show discount price which i applied the same setting as "golden-opportunity" product.
Here is working link -> www.hofs88.com/index.php/shop/relationsh...ct/158-perfect-match
Is there some configuration that we might have missed somehow?
11 years 9 months ago #186633
by lousyfool
Please double-check and verify that all products which shall be discounted are definitely in the category which you are applying the discount to. Frankly, I'm not so sure you got that right. Again, if you want discount for multiple products, they must all be in that same category as specified in the discount configuration, and a single product must not be selected there.
Eventually set "Including subcategories" to Yes.
Just in case, also make sure that in both
- System -> Configuration -> Display tab -> Default parameters for products, and
- your product listing menus and modules
- Show discounted price = Display the price before the discount is applied
- Price display method = Cheapest price
The following user(s) said Thank You: htunlinnaung
- htunlinnaung
11 years 9 months ago #186787
by htunlinnaung
Thanks you luosyfool , that is now resolved
So many thanks for your fast reply.
Time to create page: 0.339 seconds
