Prev/next button goes 16 products prev/after
11 years 9 months ago #186708 by tilemahosg
-- url of the page with the problem -- : www.photokrokidis.gr
-- Joomla version -- : 2.5.24
Hello.
I have recently created an e-shop for a photographer. They want to display their photos and anyone can buy them. The thing is that in any product, if you click the previous/next button it gets you 16 products next/previous. The products have sequential ids. I wander how this happens. Any ideas and ways to make it go sequentially?
Thanks in advance.
11 years 9 months ago #186710 by Xavier
Are the products in many categories ?
If it is, it can be the source of the issue, if they don't have the same first category.
The buttons get the products just before or after the current product based on it's main category.
So if the products have many categories, and not always the same one, so it seems to display random products.
11 years 9 months ago #186813 by tilemahosg
Hello!
The products are in the same category. I have seen already a thread that had the problem of the products belonging to many categories and that's not my problem too... I have put some products in one category (products "eikona 1" up to "eikona 3065") and some others in an other category (products "eikona 3066" up to "eikona 5055").
The thing is, that it shows products from the same category but it shows them with a "gap" of 15 products (product 1 -> product 17 -> product 33 -> product 49 e.t.c.).
11 years 9 months ago #186815 by Xavier
And in the backend, in the product listing view, are the products correctly ordered ? (order column)
11 years 9 months ago #186918 by tilemahosg
Yes they are. They also have sequential ids. Product "EIKONA 1" has id 1141, product "EIKONA 2" has id 1142 e.t.c. Is there a problem that the id starts from number 1141 and not from 1?
11 years 9 months ago #186919 by tilemahosg
I unsterstood your question now. The products aren't ordered in the order column... I'll try to order them and see what happens. Is there any way of doing that with one action?
11 years 9 months ago #186943 by tilemahosg
OK I'll do it througth the import option. But what is the column name of the order column (ordering of products)? I'll do it through product_code+ the column name of the product_order
Thanks!
11 years 9 months ago #186942 by Jerome
In the backend listing, when you display the product in "direct sub elements" and set the sorting on "order", you will be able to change the ordering number for every products in the page.
You can then click on the "save order" button (just near the "order" table title) to save the ordering.
To edit more products, just change the number in the pagination limitation.
11 years 9 months ago #187008 by tilemahosg
There are 3065 products in the 1st category and about 2000 products in the 2nd category. It'll take days to do that. Is there any other way to show the products ordered by id or to import - update the products using an extra field - column for the ordering?
11 years 9 months ago #187020 by Xavier
At this time, I don't see easy solution but do some MySQL queries with PHP value managment..
We will think to add this kind of feature in our mass action system.
11 years 9 months ago #187079 by tilemahosg
Since I have php/mysql knowledge I could do some coding. But I don't know where should I put the code and what tables / attributes should I look for. Could you please help me on that in a manual way of presenting the products?
Thanks!
11 years 9 months ago #187081 by Jerome
The table is the "hikashop_product_category" table.
In this table you will find the product id, the category id and the ordering value.
11 years 9 months ago #187150 by tilemahosg
OK thanks a lot!
I did it through MySQL update statement in phpmyadmin part of the server.
It's the "ordering" column that needed to be updated.
When I tried to access and update ordering column through csv file (tried to import csv files in order to update existing products) it couldn't do it. I couldn't recognize this column as one of the permitted ones...
I would very much appreciate if you could "fix" this and let us set the ordering number of the products through csv file!!! It would make our lives easier (I think).
Thanks a lot!
11 years 9 months ago #187180 by Jerome
The import system need some rewriting in order to support some features that we imagine some years ago ; support of ordering in categories in one of them.
With HikaMarket, I have to create an import system (which will be compatible with the vendors in the front-end) ; one of my goals is to rewrite a big part of the import for HikaMarket into HikaShop.
For the moment I'm still working on the plugin system (which is almost finished but some features won't be available before the next HikaShop release) ; after that I will work on some improvements of the order management for the vendors..
The import feature is in my TODO list with a high priority but there are also tasks with a higher priority ; so I'm afraid that I can't give you any schedule for the moment because I don't know them.
Time to create page: 0.493 seconds
