Changing Products Layout
11 years 10 months ago - 11 years 10 months ago #187325 by azhpo
-- HikaShop version -- : Free version
-- Joomla version -- : 2.5
I wanted to change the layout of my products display but can't find the file where it is displayed.
I have a few things I wanted to change (will list below) and I can't figure out how:
1. I wanted to change the display order of product's attribues (product name, price, photo). The way I list my products: I have assigned to my menu a "COM_HIKASHOP_PRODUCT_VIEW_DEFAULT_TITLE". I wanted to change the order of this products displayed. What is the file that I should change?
2. I wanted to remove the text "Without taxes" from the price, leaving just and only the price displayed itself.
3. I'm using the module for the Shopping Cart, and I wanted to display Title "Shopping Cart" and it doesn't show up. I have Show Title = Yes on the module, though it doesn't appear to show.
[strike]4. The page title for some reason shows "product category" (I guess it's the Category name) but in the menu definitions I said to show custom title but not working.[/strike]
EDIT: I got the nr. 4 working. Any help for the first 3?
I hope to get this working.
Best regards.
Last edit: 11 years 10 months ago by azhpo.
11 years 10 months ago #187330 by Xavier
Replied by Xavier on topic Changing Products Layout
First of all, here is a precious link, it explain how to customize the layout:
1. The view to edit is: "product / listing_img_title" or another listing one based on your menu/module settings.
2. You can do a translation override: www.hikashop.com/support/faq.html#tran
3. Please try to edit the Joomla settings of this module (button present in the toolbar). This module use the default Joomla module system.
4. In the options of your menu, you have to enable the option "Use menu name instead of category name for the title". Or you can rename the main product category name.
The following user(s) said Thank You: azhpo
11 years 10 months ago #187433 by azhpo
Replied by azhpo on topic Changing Products Layout
Thank you, it all works fine.
I have 2 problems now concerning the Shoping Cart display and Related products (both HS Modules).
1. I wanted to add my shopping cart in product page too. It doesn't display inside the product page. I did not change the show_default.php file. See screenshot.
2. Related products doesn't change language. It displays "Related products" instead of in french. In backend languages section it appears to be translated but it doesn't on the frontend. See screenshots.
I'm sorry if i'm doing something wrong.
11 years 10 months ago - 11 years 10 months ago #187445 by Mohamed Thelji
1. Your issue is probably coming from how you have set the "Module Assignment" Joomla option of your cart content module
2. You should use a translation extension to dynamically change the language of your modules
Last edit: 11 years 10 months ago by Mohamed Thelji.
11 years 10 months ago - 11 years 10 months ago #187768 by azhpo
All working. Thank you!
One final question.
The way I want to deliver my products is by "Collect on Delivery". I made that option, but it shows register form, which I don't want. I know that to hide the register form, I need to buy HikaShop (and I will), but will it be possible to display a form with their address, name, contact, etc (NOT a register form, but a information form)? I guess so but I just want to be sure before buying it.
[strike]EDIT: Oh by the way, my website supports 3 languages (FR, DE, IT). On the french side, it is all displaying in french correctly, but why does it display in English in the Deutch side?[/strike]
EDIT2: Nevermind, I found how to load the languages. System -> Languages and clicking on edit button will load the languages.
Thank you so much for your support.
Best regards.
11 years 10 months ago #187771 by Xavier
I think that what you are looking for is the guest checkout, so yes it is possible.
You can potentially do some tests on our demo website to see if it correspond to your needs. ;)
