- Thank you received: 5
SOLVED: Product in a Module
11 years 9 months ago - 11 years 9 months ago #188759
by ltempest
SOLVED: Product in a Module was created by ltempest
Help,
My head is spinning! I thought this would be a simple thing to achieve.
There is a standard Joomla article which display lots of information about a product within HikaShop. On the right hand side is a Joomla Custom HTML module with the add to cart HTML code pasted in.
However on the HikaShop module I cannot see how to select a specific product that will be the same as the Joomla article.
On the Custom HTML module I cannot add the product image or the Choose Options button.
I need the best of both these modules, I simply want a HikaShop module that I can specify a single product to be displayed with its image, title and Choose Options button.
How can I achieve this?
Lee
Lee
Last edit: 11 years 9 months ago by ltempest. Reason: solved
11 years 9 months ago #188786
Replied by nicolas on topic Product in a Module
Here is how to do:
You should use the Custom HTML module, but instead of adding the add to cart HTML code in it, you should add a HikaShop product insert tag:
www.hikashop.com/support/support/documen...-product-insert.html
With such tag, you can specify if you want the image, the name, the add to cart button (it will be the choose options button if you have a characteristic on your product), like for a products listing.
Here is how to do:
11 years 9 months ago #190041
by ltempest
Replied by ltempest on topic Product in a Module
Nicolas,
I have the Plugins installed and enabled, but the insert buttons do not appear on the Custom HTML module, they are present on a Joomla Article.
How can I get the product insert buttons on a Custom HTML module?
Lee
Lee
11 years 9 months ago #190053
by Jerome
Replied by Jerome on topic Product in a Module
You can use the button to get the special code while editing an article and put that exact code in your module HTML.
The following user(s) said Thank You: ltempest
11 years 9 months ago #190162
by ltempest
Jerome,
Thanks for the advice, I discovered this workaround also. You also need to ensure you have Prepare Content set to Yes in the module settings or the plugin does not function on the module code.
