Display Products as available IN-STORE only
11 years 7 months ago #195206 by kavfam
-- Joomla version -- : 3.4
-- PHP version -- : 5.3.29
-- Browser(s) name and version -- : Safari 8.0.3
-- Error-message(debug-mod must be tuned on) -- : No error message. I just want to find out if it is possible to display products that can NOT be added to the cart. I have some suppliers who require products only sold IN-STORE and no online.
I just want to find out if it is possible to display products that can NOT be added to the cart. I have some suppliers who require products only sold IN-STORE and no online. If I set the price to 0 it shows them as free which is not what I want. Can I remove the Add to Cart button for specific products and show a text that these are available IN-STORE only.
11 years 7 months ago #195214 by Xavier
You can potentially select the Quantity layout "show_simple" in the product edition page, and then edit the view "product / show_quantity" and remove the code which display the add to cart button.
11 years 7 months ago #195385 by kavfam
Thanks for the suggestion. When I try to edit the product/ show quaint view i get a security block ...
"The page you are trying to access is restricted due to a security rule.
If you believe the security rule is affecting the normal operation of your website, contact your host support team and provide detailed instructions how to recreate this error.
They will be able to assist you with rectifying the problem and adjusting the security configuration if needed."
11 years 7 months ago #195392 by Mohamed Thelji
Note that you should edit your file via "Hikashop->Display->Views".
Time to create page: 0.278 seconds
