customize administrator form - add products
11 years 7 months ago #195582 by Cammarano
-- Joomla version -- : 3.4.0.
-- PHP version -- : 5.4.38
Good evening, this support request 'was translated by google want to apologize for the shape of testyo.
I would like to customize and modify the form administrator to add a product, or remove all the items that I need, for example: I do not have "options" and "related products" I want to remove these two parameters from the form in order not to view them more '.
When I worked with Joomla 2.5 I was able to find and change the form located at: SITENAME \ administrator \ templates \ Bluestork \ html \ com_hikashop \ product \ form.php now with joomla 3.x do not know where to find it.
Thanks for the kind support!
11 years 7 months ago #195583 by Jerome
To edit the HikaShop views, the best is to use the HikaShop interface under "Display > Views" (Vizualliza > Aspetto).
Then you can filter the views by context (frontend / backend), by template etc.
So you have to select "backend", your backend template (isis) and then edit the "product / form" view.
HikaShop will create the view override in the right folder for you.
11 years 7 months ago #195713 by Cammarano
Perfect! I solved thanks to your advice, although I preferred to work directly on the file as I did last time ... If you know the file path I would be really grateful.
Thanks for your kind availability ;)
11 years 7 months ago #195714 by nicolas
The path is the same for Joomla 3.x, however, the template of the backend is not bluestork anymore. It is now called isis. But the rest of the path is the exact same.
11 years 7 months ago #195757 by Cammarano
I thought so too, but the path \ administrator \ templates \ ISIS \ html \ com_hikashop \ product \ ??? contains nothing, there is the entire path quoted but inside there is no 'no files ...
11 years 7 months ago - 11 years 7 months ago #195759 by Cammarano
Problem solved Nicolas were right ... but I was right too!
The files in that path does not exist, but making any changes as shown by Jerome and closing and reopening the route manager with FTP (filezilla) file magically comes out, that is created by the system. If you cancel after the change in "product / form", the file is deleted
thanks again
Last edit: 11 years 7 months ago by Cammarano.
11 years 7 months ago - 11 years 7 months ago #195827 by Cammarano
Good evening , unfortunately still are not satisfied with the result , I just can not figure out how to customize the page loading product ... in ' image fields that I would like to remove .
when I have to update the component changes will loose ?
Thanks for your support
11 years 7 months ago #195841 by nicolas
You actually don't even have to modify the code of the view if you want to hide these fields. Just add such CSS code in the "backend CSS file" of HikaShop under the CSS section of the Display tab of the Hikashop configuration and that will do it:
.hikashop_product_tax_id_row, .hikashop_product_manufacturer_id_row, .hikashop_product_layout_row, .hikashop_product_quantity_layout_row, .hikashop_product_sale_start_row{ display:none; }
Of course, you won't loose the change when you update HikaShop.
11 years 7 months ago #195948 by Cammarano
This solution applies to all the fields? tomorrow we work, thank you for your kindness!
11 years 7 months ago #195950 by Jerome
Yes ; just analyze the page code thanks to the browser inspector (like explained in the tutorial page).
11 years 7 months ago #196187 by Cammarano
I'm sorry, the control with filezzilla it's ok, I can not go forward because in the file backend_default.css (/ media / com_hikashop / css) I can not find:
I do not understand where wrong ...
11 years 7 months ago #196195 by Jerome
You need to read more carefully :)
11 years 7 months ago #196309 by Cammarano
when I finish this site , I will start an English course :blush: ... thank you!
Time to create page: 0.397 seconds
