Display all products like Overstock or Restaraunt
11 years 8 months ago #196186 by rodopemu
-- HikaShop version -- : 3.x
-- Joomla version -- : 3.x
-- PHP version -- : 5.4.x
Do you have knowledge of a plugin or feature that allows display of products similar to Overstock or Restaraunt.com with filter options or anything similar. I mean anything similar because the products we display are expensive and will probably need added visibility as well as filtering. Thanks.
11 years 8 months ago #196211 by nicolas
HikaShop Business has built-in filters you can configure the way you want:
www.hikashop.com/support/support/documen...-filter-listing.html
11 years 8 months ago #196316 by rodopemu
I am experimenting with filters, however, it looks like it reloads the page. I would like it to function via ajax if possible. Reloading may be ok if we can get the page to look like we want. Another problem is after loading the page it shows an empty page with the title "First Level Products" I cannot get it to filter the items correctly. Also, do you have any examples of filters that are live already that I can look at. Thanks.
11 years 7 months ago #196357 by Xavier
Yes the filters are indeed reloading the page, they are not yet working with ajax.
If you don't have the desired result, that's because you didn't set it as it should.
Are you using a module for the filters or you display them with the menu ?
If it is a module, so please check that the value entered for the "menu" option in the module settings is the id of a menu which can list all the products of the shop (so an HikaShop product listing menu)
