Feature Request: products auto publish/unpublish
11 years 7 months ago #196937 by GunnarB
-- Joomla version -- : 3.4.1
-- PHP version -- : 5.6
I would really love a switch where the fields product sale start and end would really disable the listing in the shop, not only disable to put it in the cart.
Current workaround is a mass action but that is a bit of a hassle, since the unix date has to be calculated first for selection.
For now it would help me to know where the select is for the listing, so I can alter it.
11 years 7 months ago #196943 by Jerome
In the mass action, in the "sale_end" filter you can use the value " {time} " which will be automatically replaced by the current timestamp.
So it allows you to create a generic mass action rule that could be trigger every date and will unpublish the published products with a sale_end inferior than the current {time}
11 years 7 months ago #197087 by GunnarB
Time to create page: 0.041 seconds
