Thumbnails issue / Force images size issue
- alejandrojaramiranda
11 years 7 months ago - 11 years 7 months ago #199051
by alejandrojaramiranda
Thumbnails issue / Force images size issue was created by alejandrojaramiranda
-- Joomla version -- : 3.4.0
-- PHP version -- : 5.4.27
-- Browser(s) name and version -- : Firefox 36.0.1
-- Error-message(debug-mod must be tuned on) -- : Error: No se pudo escribir en la carpeta /home/xxmyuserxx/public_html/catalogo/media/com_hikashop/upload/thumbnails/320x0f
Hello: I explain certain circumstances that would like some confirmation or correction of my conjectures.
Intro: In most of my products I use variants, and one or more images for any variant; the "Product page image height" is set to 320px and the width is not defined in order to preserve proportions.
The issue: In product view of the front-end I got the following error message:
"Error: No se pudo escribir en la carpeta /home/xxmyuserxx/public_html/catalogo/media/com_hikashop/upload/thumbnails/320x0f"
what means the system is unable to write the folder where the thumbnails should be created.
First of all, I checked for permissions via FTP: all folders have 755 permissions and files have 644 (I tried changing to 775 but the error persists).
Also, I tried deleting the issue folder: the system recreated it (as it is normal), but the error message reappeared.
I noticed (via FTP) that some of the thumbnails for the product variants were recreated in that folder (as it is expected) EXCEPT the images that are smaller than the intended output. So I tried unchecking "Force images size" (in Hika>System>Config>Main>Images) and get no error.
Ask: Does this mean that the system is not able to resize small images to a larger size view?
Should the "Force images size" add some white (or black) margin to smaller images? What is the aim of this option if not? :huh:
(All of this doesn't seem an "issue" but is not obvious what happened in my case; I've thought if someone get the same message this forum could be useful)
Last edit: 11 years 7 months ago by alejandrojaramiranda.
11 years 7 months ago #199053
by shady717
Replied by shady717 on topic Thumbnails issue / Force images size issue
1 thing that could be mis-configured is your ownership not just your permissions settings.
on ubuntu type: sudo chown -R root:www-data ./
make SURE you are on the root directory of the web host!! usually thats /var/www/sitename.com on most apache installs.
11 years 7 months ago #199054
by shady717
i'm no hikashop expert, I have a hikashop question for you. I have been trying to locate anywhere i could change the size of the products page thumbnails. without luck. modules and menu items were a breeze ..
Help!! lol
Help!! lol
11 years 7 months ago #199124
Replied by nicolas on topic Thumbnails issue / Force images size issue
@alejandrojaramiranda :
When you force the size of the thumbnails, the system expect that you provide both the height and the width. It will resize the images in order to keep the ratio and either crop the thumbnail bits or fill the empty space with blank. So if you enter 400*400 but that the original image is 800*400, if the force size option is activated, you'll get some blank in order to keep the image centered and the thumbnail will be 400*400.
If you turn off the force size option, the image with have a size of 400*200 and it won't be centered in its area.
If you enter only one dimension, then you can't have the force size option activated as the other dimension of the thumbnails will be calculated automatically based on the original image ratio and the dimension you entered.
@shady717 The size of the product page thumbnails can be changed with CSS:
www.hikashop.com/support/support/documen...ling.html#thumbnails
The following user(s) said Thank You: alejandrojaramiranda
11 years 7 months ago #199240
Replied by alejandrojaramiranda on topic Thumbnails issue / Force images size issue
Thanks Nicolas, now it's fixed following your indications (altough, note that resizing images to a mininum of 320px* (* in my case) the error messages dissapeared.
11 years 7 months ago - 11 years 7 months ago #199241
Thanks @shady717, but in this case is nothing to do with permissions or ownership. I ignore why the message say that I was not able "to write" the folder. Anyway, the issue was not indicating both, the height and width.
Last edit: 11 years 7 months ago by alejandrojaramiranda. Reason: mention to user
