- Thank you received: 4
problem adding to cart
11 years 4 months ago #206599
by jesper
Replied by jesper on topic problem adding to cart
disabled the autoban as it is a test site... try now
11 years 4 months ago #206613
by Xavier
Replied by Xavier on topic problem adding to cart
Still banned message after the htaccess password.
11 years 4 months ago #206705
by jesper
removed the script that autobans at it is just a testserver
its bb.test..... you use right ?
11 years 4 months ago #206767
by Xavier
My bad, I was using an older access. So ok I have been able to reach the backend of the test domain, and reproduced the error.
It seem to be coming indeed from the cart class, strange because when we check the value of the $do variable after calling the trigger "onBeforeCartUpdate" in the cart class the value of $do is well "true" so the product should be added in the cart...
I will do further investigation, I have no clues for the moment, keep you informed.
11 years 4 months ago #206773
by Xavier
Ok, problem solved, you have to use the function "initCart()" of the cart class after a get() or a loadFullCart().
This allow to make the cart usable back.
11 years 4 months ago #206889
by jesper
thanx that helped me fix that problem.
