Display Product Code with Variant Changes
11 years 6 months ago #202194 by sldoom
-- Joomla version -- : 3.4.1
-- PHP version -- : 5.4.37
-- Browser(s) name and version -- : Chrome 42.0
I am trying to 'stabilize' the display of the product_code. I have set Display-Display Product Code to YES. I have modified the Front-End CSS, as well as, the Display-View-show_default file. The product_code displays correctly when you open the page, but, if you choose an alternate characteristic, the page partially refreshes and reverts my changes.
I am betting I am missing something fairly simple, as I have spent several hours searching for an answer.
Thanks in advance for your help.
Scott
11 years 6 months ago #202220 by Jerome
When you change the variant, there is some javascript which replace some elements in the page with the content of the variant.
The span with id "hikashop_product_name_main" will receive the variant product name.
The span with id "hikashop_product_code_main" will receive the variant product code.
If you have customize the view "show_default", you might need to also override the "show" view to generate the same kind of HTML code for the variants.
if(!empty($variant->product_name)) { ?> <div id="hikashop_product_name_<?php echo $variant_name;?>" style="display:none;"><?php echo $variant->product_name; ?></div> <?php } if($this->config->get('show_code') && !empty($variant->product_code)) { ?> <div id="hikashop_product_code_<?php echo $variant_name;?>" style="display:none;"><?php echo $variant->product_code; ?></div> <?php }
11 years 6 months ago #202601 by sldoom
Thanks for your help. This shows where I needed to make the necessary changes.
