Products listing is showing twice
11 years 3 months ago - 11 years 3 months ago #208118 by Carolyn
-- Joomla version -- : 2.3.3
I have a small shop (only four products), therefore have created a Hikashop with product listing.
When I am on my shop homepage I can see my four products, followed by my cart, and then for some reason my four products are again displayed. (see screnshot attached)
this apparently is not linked to the cart, since it is displaying all my products and not only the products ordered.
If I unpublish my products listing, then the bottom one also disappears.
Strange thing is, I've got a multilingual site. I've created the Eshop on the English page and as far as I can see it's configured identically and yet the English page displays properly whereas the French one doesn't.
I can not see where I need to change this display problem. Can you help me??
thank you
Last edit: 11 years 3 months ago by Carolyn.
11 years 3 months ago #208122 by nicolas
Your website is in maintenance so I couldn't check the issue.
I can only suppose that it is because you have an associated products listing module enabled in the "associated modules" setting of your menu item that you can edit via the menu Display>Content menus. If so, remove the associated module and that should solve the problem.
But it could be something else as I couldn't verify that on your website.
11 years 3 months ago #208263 by Carolyn
thank you for these initial suggestions.
The site is once more online so you should be able to see the shop now. it is the "boutique" in the French menu
I have checked but not found any associated products listings.
I have noticed one other thing. When I make changes to the display by going to the module and changing the module, It only now changes the top line of products (with pale grey background) and not the bottom ones.
However, the bottom ones (with the blue background) have inherited my template style (haven - you can tell by the font) and not the top boxes.
I would be most grateful to you if you could take a look and tell me where the problem is coming from.
11 years 3 months ago #208271 by nicolas
On this page, you first have the module with the id 172 which is displayed in the top1 position of your template. Disable it in the Joomla modules manager and you won't see it.
You also have the menu of the boutique link (id 194) displaying the second products listing in the main area of the page. That should be left as it is.
The following user(s) said Thank You: Carolyn
11 years 3 months ago #208331 by Carolyn
Thank you. indeed problem solved
