Display 'null' when I'm try select products.
11 years 4 months ago #208476 by maclen2007
-- Joomla version -- : 3.4.1
-- PHP version -- : 5.4.36
In backend hikashop when I'm try select products in tab "options", they display as "null".
11 years 4 months ago #208479 by Mohamed Thelji
I just tested it and it worked fine on my end, can you tell me how did you configured/created your products ?
11 years 4 months ago #208560 by maclen2007
In other site with same last version hikashop all right. Products make very simple variant, with minimum necessary information (name product, product category, image). It's all. If necessary I can provide access to the admin.
11 years 3 months ago #208562 by Xavier
Yes please provide a backend access, you can send the informations through our contact form:
Please don't forget to give the url to that topic in your message ;)
11 years 3 months ago #208713 by nicolas
That's really strange. I tried on my end with the same product names and don't have the same issue which apparently comes from an encoding issue with the product names.
Would it be possible to also get a FTP access to your website so that we can debug directly on your website as we can't reproduce on our end ?
11 years 3 months ago #208896 by nicolas
We found the issue and fixed it. The issue came from the version of PHP you're using which was not behaving like other versions for the UTF8 support.
We've added a patch also in the install packages available on our website if someone else stumble on the same issue.
The following user(s) said Thank You: maclen2007
11 years 3 months ago #209024 by maclen2007
Thanks! All right!
