- Thank you received: 1
Move Subcategory below products listing
- christinapsarrou
11 years 4 months ago #208591
by christinapsarrou
Move Subcategory below products listing was created by christinapsarrou
-- Joomla version -- : 3.3.3
Hello!
I have an issue with the display of main category products and subcategories.
I have a main category which includes some products and an additional subcategory.
What I need is to have on top my products and below the subcategory, though I can not find a way to change this.
I already edited the category listing.php file by copying from top and pasting to bottom:
$html = $this->loadTemplate($layout_type);
if(!empty($html)) echo '<div class="hikashop_subcategories_listing">'.$html.'</div>';
This makes the change I want, but then to all my modules with categories all are duplicated. If I erase the first one, none of them are displayed.
I attach an image of what I need, I hope there is an easy way to do it and simply can not see it!
Thanks a lot!!
Hello!
Thanks a lot!!
11 years 4 months ago #208604
Replied by nicolas on topic Move Subcategory below products listing
The code was probably not pasted at a valid place in the file.
Can you provide a screenshot of how you did the change in the code so that we can see how it is now ?
- christinapsarrou
11 years 4 months ago #208752
by christinapsarrou
Replied by christinapsarrou on topic Move Subcategory below products listing
I decided to remove the subcategory and made a different reconstruction of the e-shop, so I will probably will not need the change anymore.
Thanks a lot though for your kind support!
