Category Listing without individual products.
11 years 3 months ago #209565
by markc
Category Listing without individual products. was created by markc
-- Joomla version -- : 3.4.3
-- PHP version -- : 5.3.29
In Categories Listing I get my 3 Categorys listed at the top of the page as I want. Under this I get a product listing of all the items. I have turned off the modules under "Associated modules".
I have read the documentation and searched the forum but clearly still doing something wrong. I just want to display the Product Category and not the individual items.
11 years 3 months ago #209590
Replied by nicolas on topic Category Listing without individual products.
Turning off the modules in the" associated modules" of the menu is not the solution.
HikaShop will automatically recreate the associated module for you. Otherwise, when you click on your categories, you wouldn't see any products.
What you want instead is to change the "sub element filter" setting of that associated module to "direct sub elements" instead of "all sub elements" so that it only displays the products of the current category and not the products of the sub categories of the current category.
11 years 3 months ago #209604
by markc
Replied by markc on topic Category Listing without individual products.
Thank you but I have tried that. It does not change.
11 years 3 months ago - 11 years 3 months ago #209610
by markc
I have done something silly! I thought that I might have the Category system wrong. I had 3 categorys with the "parent category" set as "product category" - I deleted the "product category" from one of my category and now I cannot edit it.
Should all my categories be sub categories of the "product Category" and if so it is possible to retrieve my error.
I have recovered this in the database. But my original problem is still a problem.
Last edit: 11 years 3 months ago by markc.
11 years 3 months ago #209612
Then that means that either you have caching on your website preventing you from seeing the change, or you added the main category of your menu to each product, which is not necessary. You should only add the categories where you want the product to display when you edit/add your product.
Or maybe you didn't edit the correct "sub element filter" option. Did you go in the menu Display>Content modules, and edited the module with the id 110 and turned off that option there ? That's the one used on your link.
You won't be able to edit it if it is considered as a root category.
You'll have to use a mass action via the menu System>Mass actions to update the category_parent_id of the category to the id of the product category based on a filter on the category_name matching with the name of the category.
Then, you can click on the "rebuild" button of the categories listing and it should display properly again.
The following user(s) said Thank You: markc
11 years 3 months ago #209649
by markc
Many thanks for your help. It is a truly brilliant produce - just takes a little while to get my head around it!
