Product not accessible from product listing page
11 years 4 months ago #209571 by valerun
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.5.3
-- Browser(s) name and version -- : mozilla firefox 38.0
-- Error-message(debug-mod must be tuned on) -- : No error message
I am working on the renovation of a joomla 2.5 website to joomla 3.3 website along with new design implementation. For the new website I have migrated the db from the old website database to new website database . I copied over all the tables of hikashop into the new database .
All the products and categories turned up fine. But now when I click on a individual product from the product listing I am redirected back to the product listing page only.
This is the store url ( emotorwerks.com/newsitetest/emotorwerks/index.php/store ). This is one of the product url ( emotorwerks.com/newsitetest/emotorwerks/...e-with-24-foot-cable ) . No matter what changes i make to the url after the "store" it always takes me to the same product listing page. I am not sure whether this is the problem of database migration or some configuration related problem.Moreover, the cart is also not able to delete selected products . Please take a look into it .
11 years 4 months ago #209577 by Jerome
Would it be possible to know more about your Joomla menu "store" configuration and your HikaShop SEF configuration.
It looks like a SEF issue because if you generate a non-SEF url, the page is working.
Afterwards, it could be also link to the "canonical" configuration of your products and your HikaShop settings for the canonical management.
The following user(s) said Thank You: valerun
11 years 4 months ago #209638 by valerun
Hi Jerome,
Thanks for your reply. I have successfully resolved the issue by choosing the "generate and use sef urls " configuration. Thanks much . But now I am facing a very strange problem that the product chosen by one user are also appearing to the other users on the website. Hikashop must be using cookies for cart management . But even if I delete my cookie I still get the older details of the product earlier chosen. Any idea what might be causing it ?
11 years 4 months ago #209661 by nicolas
HikaShop doesn't use cookies.
This would be possible either if you would have problems with your server regarding the Joomla session (you can try to change the "session handler" setting of the Joomla configuration and see if that helps), or if you had a caching issue (you can try to turn off the caching setting of the Joomla configuration and/or the joomla cache system plugin via the Joomla plugins manager).
