SEO urls problem
- raven-worx
11 years 3 months ago #209755
by raven-worx
SEO urls problem was created by raven-worx
-- Joomla version -- : 3.4.3
-- PHP version -- : 5.4
i created the main part of my website with SEO turned off in the joonla settings.
When i was almost finished i turned it on and imported some new products.
Those newly created products resulted in a 404 error. So i turned the SEO option off again.
Now everything works except:
1) The newly added products still have SEO urls, all old products have the standard joomla urls. But both work.
2) when using the joomla search the newly created products have the SEO urls with "?option=com_search&Itemid=9999" appended at the end. Which of course doesn't work at all.
So how can i trigger to recreate the SEO urls of products?
11 years 3 months ago #209756
by Jerome
Replied by Jerome on topic SEO urls problem
Please check your SEF settings in HikaShop.
www.hikashop.com/support/support/documen...ig.html#features_sef
If you're providing/generating wrong canonical URL and you force HikaShop to use that URL ; it will result a lot of 404 pages.
At this moment I'll recommend you to clean your canonical url or do not activate the setting to force it.
- raven-worx
11 years 3 months ago #209794
by raven-worx
Replied by raven-worx on topic SEO urls problem
ok, now i've set "Force canonical URLs on listings" to "No, generate the URLs"
The shop frontend now works again as expected.
But the issue with the search-result (from com_search) are still using the wrong SEF url (with "?option=com_search&Itemid=9999" appended)
11 years 3 months ago #209803
Replied by nicolas on topic SEO urls problem
That's probably because in the "itemid" setting of the HikaShop products search plugin, you entered the id 9999 instead of the id of a HikaShop products listing menu item. So please check that setting.
- raven-worx
11 years 3 months ago #210085
by raven-worx
I've checked that. I didn't specify (empty) an ItemId in the settings of the search module.
So i checked the template overrides and there was one available so i temporarily disabled it. And even with Joomla's 'original' search module the problem exists and behaves the same.
The hikashop search plugin returns a SEF url and appends some additionally parameters. The urls are fine for all other products.
When "?option=com_search&Itemid=9999" gets appended the user is redirected to the search component instead of com_hikashop. I also removed the ItemId from the code to check, but then the currents page ItemId is taken instead, so no change.
There is just something wrong with the URLs generated for the newly imported products while SEO was enabled in the joomla settings.
11 years 3 months ago #210094
As I said, you need to enter the id of a menu item of the type HikaShop products listing in the Itemid setting of the plugin.
Try that and that should hopefully help.
- raven-worx
11 years 3 months ago - 11 years 3 months ago #210243
by raven-worx
specifying the itemid in the hikashop search plugin only affects the already working products - the ones where not the SEO url is generated.
The non working ones are unaffected.
Since we have ~22.000 products listed in the shop i didn't notice that there are also older imported products which do not work.
So whats taken into account for creating the SEO url? Why are still SEO urls generated when SEO is disabled?!
Last edit: 11 years 3 months ago by raven-worx.
11 years 3 months ago #210248
If you don't see any change in the URL of some of the products, it probably means that you have a URL set in the "canonical URL" field of the product and the system is using that URL instead of generating one.
So make sure that this canonical URL is correct.
- raven-worx
11 years 3 months ago #210454
by raven-worx
yes, it seems that was the issue.
There were about 80 products with a canonical url specified. But how it comes? I never entered any value there?
Is it autoamtically filled when SEO is enabled and the product is viewed (in the frontend)?
11 years 3 months ago #210477
It is automatically filled if you have the "force canonical URL on listing" setting set to "Use canonical URL and generate it if missing" in the HikaShop configuration and that it is empty, which is not the case by default.
That way, the link to the product page will always be the same.
But if later on you change the menu structure of your website, the link there might be incorrect and thus you'll have to empty the canonical URL field of the products again.
