Responsiveness problems and Bootstrap option
11 years 3 months ago #211233 by SarahW
-- url of the page with the problem -- : www.thelavenderlady.co.uk/index.php/shop
-- Joomla version -- : 3.4.3
-- PHP version -- : 5.5.2.7
-- Browser(s) name and version -- : Firefox 39.0.3, Chrome 44.0.2403.130m
I've created templates for two Joomla/HikaShop sites using Themler, and I have the same problem on both: with the HikaShop option 'Use Bootstrap design' on, a category product listing displays in a single column even when it's set to display in multiple columns; with the option off, the product listing displays correctly but is not properly responsive (items overlap on a small screen). The site linked here currently has 'Use Bootstrap design' turned off.
The Themler template uses Bootstrap, so I'm guessing that it might be a question of pointing Hikashop at the right CSS - but I don't know how to do that. Any help gratefully accepted.
11 years 3 months ago #211235 by lousyfool
Your template seems to load some Bootstrap 3, but not Bootstrap 2. But HikaShop is, like native Joomla, supporting only Bootstrap 2 (though BS 3 support is under way, I hear).
So, turning Bootstrap off in HikaShop is the right thing to do for you. "Missing responsiveness" can then be added with custom CSS and media queries, such as
@media (max-width: 767px) { .hikashop_products_listing .hikashop_product {width: 100% !important;} }
for product listings such as in the page you're linking to.
In case you wonder, here is documentation on how to do so: www.hikashop.com/support/support/documen...ize-the-display.html
More similar code may be required for other shop elements or pages, of course. But so it goes if things aren't 100% compatible out of the box, and I'm sure you'll find more support here if you need it. ;)
The following user(s) said Thank You: Jerome, SarahW, jconn
11 years 3 months ago #211242 by SarahW
Great - thanks very much for that lousyfool. Really helpful :)
9 years 9 months ago #260970 by river
Joomla 3.6.5
Hikashop 3
Protostar template
NOTE: This i regarding hikashop 3
I've set the HikaShop » Products listing !>Div to display 3 Rows with products.
This also works perfect on my iPad in wide view.
But on the my iPad in "Narrow view" it only displays the products in 1 rtow, and I want it to display the products in 2 rows.
Any advice on what CSS code I can use to get the Products listing to display to rows with products in iPAD narrow view ?
9 years 9 months ago #260973 by Jerome
HikaShop 3 do not have any relation with Bootstrap ; it uses his own responsive grid system now.
Please use another thread in the forum and create a new one if necessary.
