Custom fields not showing in a duplicated Product
11 years 3 months ago #212574 by sapura
-- Joomla version -- : 3.4.1
-- PHP version -- : 5.5.25
-- Error-message(debug-mod must be tuned on) -- : Not showing the Custom Product fields on this page (duplicated product).
But it's showing on the original product /index.php/product/24-macbook-air-13
I have created 2 custom fields (Tech Specs and Battery & Power) in product table.
Worked fine and appears in my ProductA : /index.php/product/24-macbook-air-13
However, I duplicated this product (ProductB), the custom fields have the same values. But now they are not showing.
/index.php/sit/product/71-macbook-air-13-inch-1-6ghz
Any idea how it can be showing for one and not the other (esp when it's a duplicate)?
11 years 2 months ago #212618 by nicolas
It probably comes from the settings of your custom field then.
You must have limited the custom field to only the product A and not the product B.
Could you provide a screenshot of the settings of the custom field and a screenshot of the settings of the product ?
11 years 2 months ago #212684 by sapura
Hi Nicolas, please see attached. Thanks!
Custom Field Settings:
Product Showing Field:
Product NOT Showing Field:
11 years 2 months ago #212709 by nicolas
The only reason I can see is that in your second product, you entered something in your custom field in the variants of the product.
Please check the variants and make sure that the custom fields are empty there.
11 years 2 months ago - 11 years 2 months ago #212877 by sapura
Where do you see that?
Ok. Problem solved. When I added variants, somehow it automatically put spaces in the fields. No idea why..
Thanks for your trouble.
Last edit: 11 years 2 months ago by sapura.
