Hikashop module display not responsive, help!
11 years 2 months ago - 11 years 2 months ago #212780 by Rocco fx
-- Joomla version -- : 3.4.3
Hi, sorry my english please, i have the next problems:
1- When creating products and display in 2+ blocks layout and the page becomes smaller, all info and image becomes really small (like trying to make the hole module responsive) so finally producs remain into 2+ colums but cant be seen well, if the product boxes were responsive they should stay one on top of the other when resizing and just resize images a bit, and not resize the hole module, what can i do?
2 -When creating products and display in tables layout i get opposite problem: the image isnt responsive, so the name of the product cant be seen because while the page becomes smaller the image doesnt resize.
3-Question: How can i display products individually into modules, like decide the ID for a mudule then only that selected product appears at that module?
Attached pics, please help
Last edit: 11 years 2 months ago by Rocco fx.
11 years 2 months ago #212846 by lousyfool
1. It depends on your template and its CSS. Eventually you get a better result when changing the HikaShop setting for "Use Bootstrap design": www.hikashop.com/support/documentation/i...html#display_general
If that doesn't improve things, you might need to add custom CSS with media queries.
2. HTML tables are not responsive, indeed, at least not easily. You could eventually improve things - again - with custom CSS and media queries, but it will never be fully "responsive" when using a table.
3. Look here: www.hikashop.com/forum/product-category-...uct-in-a-module.html
11 years 2 months ago #212823 by Jerome
The content will be responsive if you use a responsive design : a template with support of boostrap 2 (and only bootstrap 2) and the setting "use bootstrap design" in HikaShop.
11 years 2 months ago - 11 years 2 months ago #212967 by Rocco fx
HI
Im using Purity III, i changed options as mentioned on #1 and then the boxes became tables like, one on top of another (wich is the look i wanted for small screen not wide) and also made my site wider so it looks bad, as i didnt like it, returned to the previous options but my site remained wider... so now my design crosses the screen wide size, and only desactivating Hikashop component my site becomes normal size, why that happened and how i can fix it? do i have to reinstall hikashop?
What type of CSS can i add? so in boxes style on wider screens product will be next to each other and in cellphones products will be one on top of another? how to do it, please help with some steps because im not an expert at css or html.
Thanks a lot
11 years 2 months ago #212969 by Rocco fx
Adding the products into an html module isnt working right, the products looks not centered, wide insted of boxes style, the text all over the place, i added a picture...this is the code suggested:
€ 60,00 HikaShop Essential Add to cart
:( thanks aniway
11 years 2 months ago #213000 by nicolas
As Jerome said, the "use bootstrap design" option which handle the responsive system will only work fine if your Joomla template supports bootstrap 2.
The purity 3 template only supports bootstrap 3 so that explains why it doesn't display right.
You can make it work with this tip:
www.hikashop.com/forum/4-how-to/865505-b...hikashop.html#142070
Regarding the product content tag, it doesn't handle multiple columns. If you want a products listing with multiple columns, then that's not what you want to use. Instead, you'll want to setup a products listing module and use the extension Modules anywhere in order to add the tag displaying the module where you want.
11 years 2 months ago - 11 years 2 months ago #213083 by Rocco fx
nicolas wrote: Hi,
We havent found any "boostrap 2" template like purity III, we use purity because its easy to handle layouts, but making a search for only bootstrap 2 templates, the resoults are Joomla 3 templates wich many are bootstrap 3 and difficult to stablish wich is bootstrap 2 or 3 since they only say they are "bootstrap" lol, but thanks for the tip.
nicolas wrote: Hi,
Hi, added an attachment of the exactly design i need, boxes of products that responsively change from a row of 4 in widescreen to a row of 2 in medium screen and a sinlge row for cellphone screen, please help with detailed steps, since im not an expert in html or php, also i need a before price and after with a line crossed like in the attachment.
Please help
11 years 2 months ago #213084 by Jerome
feels like going backwards with hikashop
Joomla 3 only provide support for bootstrap 2, the libraries and tools provided are made for bootstrap 2.
And if you take a look at the link that Nicolas gave you ; you will find the way to activate the support of bootstrap 3 in HikaShop.
So I really don't understand why you are saying that you're going backwards.
HikaShop is compatible with the view override system ; which means that you can override every views and you can put the required classes and needed HTML for the Bootstrap 3 support.
Most of template compatible with HikaShop are using some kind of feature in order to provide a good integration between HikaShop and their template.
Now if a bootstrap 3 template want to have an integration with HikaShop, it can.
It is not really the job to HikaShop to provide that ; we are following the Joomla specifications, so we are supporting bootstrap 2.
It's not the HikaShop role but we have a (hidden) feature anyway ; because we are nice.
