Related Products add to cart button problem
- dilum_tharaka
11 years 2 months ago - 10 years 6 months ago #213556
by dilum_tharaka
Related Products add to cart button problem was created by dilum_tharaka
maus.development.kandytech.net/shop-online/mouse
-- Joomla version -- : 3.4.3
-- PHP version -- : 5.5.28
-- Browser(s) name and version -- : Mozilla Firefox 40.0.3
I'm using the Related products module.
The module is displaying "Choose option" instead of "add to cart button".I tried to fix this but couldn't find a way.
How can I replace the Choose Options with the Add to cart button.
I would greatly appreciate any help.
Dilum.
Dilum.
Last edit: 10 years 6 months ago by dilum_tharaka.
- dilum_tharaka
11 years 2 months ago - 11 years 2 months ago #213599
by dilum_tharaka
Replied by dilum_tharaka on topic Related Products add to cart button problem
I found a way to do this.
Now I don't want the related products under the product, I want it to the right.
How can I do this?
How can I do this?
Last edit: 11 years 2 months ago by dilum_tharaka.
- Thank you received: 1778
11 years 2 months ago #213620
by Mohamed Thelji
Replied by Mohamed Thelji on topic Related Products add to cart button problem
To do that you'll just have to unset your product module from the "Modules to display under the main area" option via "Hikashop->System->Configuration->Display", and directly use the "Position" option through your Joomla module configuration page to move your module.
The following user(s) said Thank You: dilum_tharaka
- dilum_tharaka
11 years 2 months ago #213675
by dilum_tharaka
Thank you Mohamed,
Very clear instructions.
- dilum_tharaka
10 years 6 months ago #238547
by dilum_tharaka
I know this is a old post, but didn't want to create a new one under same category. So I'm writing this here.
I'm using a content module to display the related products. It was working fine, but with latest hikashop update, my products are redirected to different product page. You can check this here: mausfish.com/shop-online/fly-mouse
I will also attach a screenshot for this: joxi.ru/l2ZnEXgh8W3jd2 (Hikashop related product module settings is also attached. )
What can I do to fix this?
Thanks,
Dilum
Thanks,
Dilum
10 years 6 months ago #238552
Replied by nicolas on topic Related Products add to cart button problem
The problem is probably that you didn't select your "shop online" menu item in the "menu" setting of your related products module. Please check that.
- dilum_tharaka
10 years 6 months ago #238621
by dilum_tharaka
Hello Nicolas , Thanks for replying.
Weird thing is that the shop online menu item s not visible. Tried few times but still it's not showing up.
joxi.ru/gmv6z85sxbEk9m Screenshot is attached.
10 years 6 months ago #238644
by Xavier
Replied by Xavier on topic Related Products add to cart button problem
Could you give us screenshots of your "shop-online" menu settings ?
If you try to create a new "product listing" menu, is it visible in the module "menu" dropdown ?
- dilum_tharaka
10 years 6 months ago #238743
by dilum_tharaka
I'm using 'single article' menu type for shop online page, as I wanted to develop the shop online page separately. I can give you admin details if you want.
10 years 6 months ago #238763
Ok I see the problem.
You can't use the shop online menu item since it's not a HikaShop menu item.
So what you want to do instead is to enter the URL you want for the product in the "canonical URL" of each product and then turn on the "force canonical URLs on listings" setting of the HikaShop configuration. That will solve the problem.
- dilum_tharaka
10 years 6 months ago #238778
by dilum_tharaka
Thanks Nicolas it worked.
Time to create page: 0.099 seconds
