- Thank you received: 3
Visible modules when entering products
11 years 1 week ago #215477
by picht
Visible modules when entering products was created by picht
-- Joomla version -- : 3.4.4
-- PHP version -- : 5.6
When I select a product from the front page on my website I get to the products page.
But all the modules in Joomla that should only be visible on the front page are still visible. E.g the big picture on the front page and news modules etc.
The modules are set to only be visible on the front page
Best regards
Picht
Best regards
Picht
11 years 1 week ago #215483
by Jerome
Replied by Jerome on topic Visible modules when entering products
You have to select a "menu" in your module configuration in order to not use the same menu that the page which is displaying the module.
See : www.hikashop.com/support/documentation/i...es-form.html#details
11 years 1 week ago #215508
by picht
Replied by picht on topic Visible modules when entering products
I'm not sure I can do what you describe.
Here is my setup:
On my front page my menuitem is a Hika-shop products listing.
I have some additional modules (not HIKA shop) shown also. Some of them are set to only show when the menu item for the front page is selected.
When i click on a product from that front page the modules (not HIKA shop) are still shown.
regards
Picht
Here is my setup:
regards
Picht
11 years 1 week ago #215525
by Xavier
Replied by Xavier on topic Visible modules when entering products
In that case you will need the plugin "Advanced module manager", it allow to handle more deeply the display of the modules based on the page contents.
11 years 2 days ago #216227
by picht
Thanks, i will look into that plugin.
Time to create page: 0.166 seconds
