Product listing shows products twice
11 years 1 month ago #215478 by sfakos
-- HikaShop version -- : latest starte edition
-- Joomla version -- : 3.3.1
-- PHP version -- : 5.2
-- Browser(s) name and version -- : firefox latest
Hallo,
My problem is that on every product listing page i create my products being displayed twice. I ve searched the forum but i do not get the solution.
Also when i tried to save the configuration file i get a 403 error claiming that i do not have the right to access the configuration file.
Thanks in advance
11 years 1 month ago #215485 by Jerome
Would it be possible to have a screenshot of your menu configuration ?
Did you create your category listing menu + product listing module with HikaShop 2.5.0 or HikaShop 2.6.0 ?
11 years 1 month ago #215491 by sfakos
What do you want me to snapshot exactly?
11 years 1 month ago #215495 by Jerome
Do you know how you configured your product listing ?
11 years 1 month ago #215504 by sfakos
In fact this is the first time i use your product. I ve been working on virtuemart for so far but i wanted to try sth different this time. I didn't though it would be so difficult. I will send you the snapshots. Do you have any other suggestions for my second problem wit the 403 error on saving configurtion?
Thanks for your time and effort.
11 years 1 month ago #215524 by sfakos
Here are the snapshots
11 years 1 month ago #215541 by Jerome
HikaShop 2.6.0 has been release very recently and include the new interface for the menu/module edition.
Because that feature is really new ; it is possible that it contains some bugs.
That's mostly why I wanted to know if you created your menu configuration with HikaShop 2.5.0 ("old" interface) or with HikaShop 2.6.0 (new interface).
Would it be possible to have an access to your backend so we can check directly your configuration and understand what is wrong ?
It will help us to reproduce the issue, provide a fix and continue to improve the software.
To send us send kind of private information, the best is to use our "contact us" form with a link to that forum thread.
11 years 1 month ago #215553 by sfakos
I did as you said. I send the login info. Plz help
11 years 1 month ago #215556 by Jerome
Thanks for the accesses.
Regarding your configuration, it looks like you were using HikaShop 2.5.0 when you create your menus.
I can see in your Joomla backend that you have some "Associated products listing for category listing menu XXX" and these modules were created by the previous interface.
So I deleted the associated module for your menu "337" and now the page is display fine.
We are currently working on a patch in order to avoid that issue ; we will create new packages as soon as possible.
The following user(s) said Thank You: sfakos
11 years 1 month ago #215574 by ppetree
I went through this VERY problem and, if you ask me, it's a bug in hikashop.
www.hikashop.com/forum/product-category-...s-of-everything.html
What I did was blow off the entire installation, clear the cache then reinstalled and when install prompted me to setup products I did used that code instead of thinking I could just simply create a product.
11 years 1 month ago #215590 by sfakos
Whst about the other problem with the 403 error. I cannot work beacause i cannot configure your product.
11 years 1 month ago #215660 by sfakos
Hello
Sorry for persisting on this but would it be possible for you to apply the same solution for me too.
I am loosing time and money all this period and i am exposed to my client. If you think it would help plz apply it.
11 years 1 month ago #215672 by nicolas
The error
Forbidden
You don't have permission to access /administrator/index.php on this server.
when you save the HikaShop configuration comes from the settings of your web server.
We cannot help you with that and you need to contact your hosting company in order to fix that problem. It usually comes from a setting of the SuHoSin PHP module.
11 years 1 month ago #216642 by sfakos
Unfortunately i have the same problems again and i cannot figured it out.
www.distill.gr/index.php?option=com_hika...t=listing&Itemid=337
At the above product page i only want to show the products under the GIN headline and not the rest of them.
But your component keeps displaying all subcategories and the main category.
Please help
I am exposed to my clientele.
11 years 1 month ago #216643 by Jerome
Please follow these indications.
11 years 1 month ago #216876 by sfakos
I am sorry for persisting but i cannot understand what the problem is and what you want me to do.
No matter what i changed the problem was not fixed.
Your component instead of displaying the products of only one category it displays all products.
I beg for your help
11 years 1 month ago #217033 by Xavier
We made a patch for this issue, so please download the latest version of HikaShop from our website and install it over your current install, that will fix your problem.
The solution of the previous message was to delete all the "associated modules" via the Joomla modules manager.
