Additions to an order to add to total...
10 years 11 months ago #217052 by ninecircles
-- url of the page with the problem -- : www.davebarrettdesigns.co.uk/yummyprint3...p/product/6-leaflets
-- Joomla version -- : 3
-- PHP version -- : 5.5
Hello clever people...
I am building a site which needs some advanced configuration and I don't know how to do it.
The site is a Web to Print provider... I am using the free HikaShop module and I want to make a few customisations that I don't know how to do.
All I need is one example built correctly so I can emulate it throughout the site...
The site is on a development server at the moment so not live...
What I want to do is have a HikaShop product page which shows:
Example - "Printed Folded Leaflets"
Text Left - Image right - then
Field for "Quantity to be printed" with price calculated after choosing a quantity...
Field for "Paper Type" (10 options on a drop down) with price calculated and added to Total
Field for Folds (one, two or three) to be added if selected with price calculated and added to Total
Field for Lamination (matte or gloss) to be added if selected with price calculated and added to Total
I managed to populate a dropdown list with variants in but they don't add to the price total and they don't output to any kind of Order Form...
It just needs to work, doesn't have to be in a dropdown like shown below...
example attached below
how I want it to look
www.davebarrettdesigns.co.uk/yummyprint3...p//folded-leaflets-m
how it currently looks
Just need the additions to add a cost to the title then give some kind of summary of the work to be done.
Just cannot work out how this is done.
Would be really grateful if someone could help me
Thanking you in anticipation
Dave
10 years 11 months ago #217080 by nicolas
1. If you want your dropdowns to add their amount to the price of the main product, you want to use options:
www.hikashop.com/support/support/documen...ct-form.html#options
2. Regarding the arranging of the layout of the product page, if you want to change it, you need to edit the file "show_default" of the view "product" via the menu Display>Views.
The following user(s) said Thank You: ninecircles
10 years 11 months ago #217128 by ninecircles
Thank you so much - I shall try this and see how I get on.
D
Time to create page: 0.161 seconds
