Using same values in custom field
10 years 11 months ago #219047
by ICT-klus
Using same values in custom field was created by ICT-klus
I have made a custom field and add some values to it. I want to use the value for price calculating. When I use a value that I used before the record is overridden. Is it possible to use the same value in a custom field? How should I work around?
10 years 11 months ago #219048
by Jerome
Replied by Jerome on topic Using same values in custom field
Please details.
With the current elements you gave ; it is just not possible to understand what you're talking about.
Please details.
Time to create page: 0.151 seconds
