Products on Category Menu Disappeared
10 years 11 months ago #221254 by wolfhome
i think maybe this is the problem,
when i go to the categoires on hikashop, most of them are set to "product category" instead of the correct one (example the attached screen shot was orginally set to "lighting" category)
as you can see there is an error message coming up when i change it and try saving.
Same thing happen on the other categories as well.
10 years 11 months ago #221321 by Konstantin1996
We activated the FTP with the login details we previously sent, please check. :cheer:
Kind Regards,
10 years 11 months ago - 10 years 11 months ago #221282 by Xavier
@wolfhome
Do you mean for the parent category option ?
Could you try to use the "Rebuild" button in the toolbar on the category listing page in backend and then try to save again ?
@Konstantin1996
The issue is due to the override you have on the view "category / listing". I tried to remove it and it then worked as expected.
I put it back to your version, but please consider to do a backup remove the override and port back your modifications.
Last edit: 10 years 11 months ago by Xavier.
10 years 11 months ago #221350 by Konstantin1996
How can I remove the override please guide me.
Kind Regards,
10 years 11 months ago #221383 by wolfhome
i did that as well and it still did not work, and yeah i mean the paretn category option, it just won't let me change it from "product category"
10 years 11 months ago #221536 by Xavier
@Konstantin1996
Go in the menu Display>Views and search for the view file. Then, in the "remove customization" column, you'll find a x icon that you can use to delete the override on the view file.
@wolfhome
Could you provide a backend access via our contact form ? (with a link to that topic).
hikashop.com/support/contact-us.html
10 years 11 months ago #221672 by wolfhome
I sent over the info.
10 years 11 months ago #221728 by Xavier
@wolfhome:
I just tried to create a new category and set a parent category, no issues. Everything seems to be working as expected.
After looking deeply at your screenshot, I see that you were trying to apply the current category as main category.
You category is "Lighting" and you were selecting "Lighting" as parent category, that can't work ;)
10 years 11 months ago #221768 by Konstantin1996
Which file should i look for? i can not find the "view file" can you please be specific.
Kind Regards,
10 years 11 months ago #221777 by wolfhome
I understand what you mean and i realise that after i posted, however the problem still exist on the front end where the categories are not displaying at all.
Products display ok, but now categories, if you click on any of the main category on my menu you will see it's coming up blank.
10 years 11 months ago - 10 years 11 months ago #221793 by Xavier
@Konstantin1996:
The view to edit is "cateegory / listing" as on this screenshot: take.ms/V0NTZ
@wolfhome:
What is the menu used in backend to display the content ? You have a lot of menus actually. ;)
10 years 11 months ago #222418 by wolfhome
hi, sorry for the late reply
its the one called swmegamenu
10 years 11 months ago #222439 by Xavier
After a lot of debug, views modifications, etc.
I saw that it was only a css property which were hiding the content:
#tz-component .hikashop_categories_listing_main .hikashop_subcategories_listing .hikashop_subcategories { display: none; }
In your template.css file line 6847...
So please remove this display:none; property.
10 years 11 months ago #222565 by wolfhome
Hi, i removed that line but still no categories are showing up.
10 years 11 months ago #222599 by Xavier
The property was applied but due to the cache the changes were not displayed.
