Help Discont
10 years 11 months ago #221237 by gentile.franc
Help Discont was created by gentile.franc
-- url of the page with the problem -- : www.viviemozioni.it/sabina-lumache/lumac...nte-da-cucinare.html
-- HikaShop version -- : 2.6
-- Joomla version -- : 3.4.4
-- PHP version -- : 5.6
-- Error-message(debug-mod must be tuned on) -- : Errore discount
Hi, the product page when I insert the vriante appears the initial price and then discount is negative.
The page reference is:
www.viviemozioni.it/le-offerte/dettaglio...nte-da-cucinare.html
help me thanks
10 years 11 months ago #221311 by Xavier
Replied by Xavier on topic Help Discont
Please check the settings of the discount you created, you potentially set a negative value instead of a positive one.
Then for the display you maybe have an override on the view "product / listing_price" too, which is not handling the discounts correctly.
10 years 11 months ago #221330 by gentile.franc
Replied by gentile.franc on topic Help Discont
Xavier Thanks for your response. I attach screenshots.
Let me explain better:
If I put the price of the product screen backend and the variant, the price did not appear as an option in the original file version.
Example:
product 1kg Price not granted € 20.00 Discounted price € 10.00
Variant:
1) Product 5kg Price not granted (where I go inside?) Discounted price € 30.00
2) Product 10kg Price not granted (where I go inside?) Discounted price € 50.00
I do not understand because it lacks a field
Help
Thanks a lot
10 years 11 months ago #221443 by Jerome
Replied by Jerome on topic Help Discont
Okay ; let's be really clear right now.
You created two topics for the same exact issue.
Here a link to the other thread : www.hikashop.com/forum/product-category-...0-hell-discount.html
Please choose and use one single thread.
One will be close and one will continue to exists.
Thanks you for your understanding and not making the support team waste some time to answer twice for the same question.
Time to create page: 0.185 seconds
