Minimum quantity per order
10 years 11 months ago #222099 by co88agency
-- HikaShop version -- : 2.6.0 Business
-- Joomla version -- : 3.4.5
-- PHP version -- : 5.5.29
Hi, is possible to show written "minimum quantity per order" in every product characteristic?
Thanks and best regards,
Loredana
10 years 11 months ago #222105 by nicolas
Replied by nicolas on topic Minimum quantity per order
I'm sorry but I don't understand where you want to display that.
In the dropdown of the characteristics ?
Could you do a screenshot so that we can understand where you want to add that text ?
10 years 11 months ago #222168 by co88agency
I'm sorry... something like in the picture...
Thanks...
Best regards,
Loredana
10 years 11 months ago #222177 by nicolas
So I suppose that this is the variants listing of a product page.
You can edit the file show_block_characteristic in the menu Display>Views in order to add custom code there after the listing_price display block.
10 years 11 months ago - 10 years 11 months ago #222279 by co88agency
I'm sorry, you don't understand me...
I want to display "Minimum quantity per order" phrase.
Best regards,
Loredana
Last edit: 10 years 11 months ago by co88agency.
10 years 11 months ago #222280 by Jerome
Replied by Jerome on topic Minimum quantity per order
Nicolas perfectly understood the situation and his last answer is your solution.
10 years 11 months ago #222342 by co88agency
if I edit that file "Miimum quantity per order" doesn't appear...
Loredana
10 years 11 months ago #222344 by nicolas
How did you modify that file ? Where did you add that code ? Did you modify that file for your frontend template, not another template ?
10 years 11 months ago #222731 by co88agency
this is my file:
<?php /** * @package HikaShop for Joomla! * @version 2.6.0 * @author hikashop.com * @copyright (C) 2010-2015 HIKARI SOFTWARE. All rights reserved. * @license GNU/GPLv3 http://www.gnu.org/licenses/gpl-3.0.html */ defined('_JEXEC') or die('Restricted access'); ?><?php if(empty($this->element->characteristics)) return; ?><div id="hikashop_product_characteristics" class="hikashop_product_characteristics"><?php if($this->params->get('characteristic_display') != 'list') { echo $this->characteristic->displayFE($this->element, $this->params) . '</div>'; return; } if(!empty($this->element->main->characteristics)) { $display = array('images'=>false, 'variant_name'=>false, 'product_description'=>false, 'prices'=>false); $main_images = ''; if(!empty($this->element->main->images)) { foreach($this->element->main->images as $image) { $main_images .= '|' . $image->file_path; } } $main_prices = ''; if(!empty($this->element->main->prices)) { foreach($this->element->main->prices as $price) { $main_prices .= '|' . $price->price_value . '_' . $price->price_currency_id; } } foreach($this->element->variants as $variant) { foreach($display as $k => $v) { if(isset($variant->$k) && !is_array($variant->$k) && !empty($variant->$k)) $display[$k] = true; } $variant_images = ''; if(!empty($this->element->main->images) && !empty($variant->images)) { foreach($variant->images as $image) { $variant_images .= '|' . $image->file_path; } } if($variant_images != $main_images) $display['images'] = true; $variant_prices = ''; if(!empty($variant->prices)) { foreach($variant->prices as $price) { $variant_prices .= '|' . $price->price_value . '_' . $price->price_currency_id; } } if($variant_prices!=$main_prices) $display['prices'] = true; } $columns=0; if((int)$this->config->get('show_quantity_field') >= 2) { ?> <form action="<?php echo hikashop_completeLink('product&task=updatecart'); ?>" method="post" name="hikashop_product_form_variants" enctype="multipart/form-data"> <?php } ?> <table class="hikashop_variants_table hikashop_products_table adminlist table table-striped table-hover" cellpadding="1"> <thead class="hikashop_variants_table_thead"> <tr class="hikashop_variants_table_thead_tr"> <?php if($this->config->get('thumbnail') && $display['images']) { $columns++; ?> <th class="hikashop_product_image title hikashop_variants_table_th"><?php echo JText::_( 'HIKA_IMAGE' ); ?></th> <?php } if($display['variant_name']) { $columns++; ?> <th class="hikashop_product_name title hikashop_variants_table_th"><?php echo JText::_( 'PRODUCT' ); ?></th> <?php } if($this->config->get('show_code')) { $columns++; ?> <th class="hikashop_product_code_title hikashop_variants_table_th"><?php echo JText::_( 'PRODUCT_CODE' ); ?></th> <?php } foreach($this->element->main->characteristics as $characteristic) { $columns++; ?> <th class="hikashop_product_characteristic hikashop_product_characteristic_<?php echo $characteristic->characteristic_id; ?> title hikashop_variants_table_th"></th> <?php } if($display['product_description']) { $columns++; ?> <th class="hikashop_product_description title hikashop_variants_table_th"><?php echo JText::_( 'HIKA_DESCRIPTION' ); ?></th> <?php } if($this->params->get('show_price','-1') == '-1') { $this->params->set('show_price', $this->config->get('show_price')); } if($this->params->get('show_price') && $display['prices']) { $columns++; ?> <th class="hikashop_product_price title hikashop_variants_table_th"><?php echo JText::_('PRICE'); ?></th> <?php } if(!$this->params->get('catalogue')){ $columns++; ?> <th class="hikashop_product_add_to_cart title hikashop_variants_table_th"><?php echo JText::_('QUANTITY_LAYOUT'); ?> </th> <?php } ?> </tr> </thead> <tbody class="hikashop_variants_table_tbody"> <?php $productClass = hikashop_get('class.product'); $productClass->generateVariantData($this->element); foreach($this->element->variants as $variant) { if(isset($variant->map)) continue; if(!$this->config->get('show_out_of_stock', 1) && $variant->product_quantity == 0) continue; if(!$variant->product_published) continue; $this->row =& $variant; ?> <tr id="hikashop_variant_row_<?php echo $variant->product_id; ?>" class="hikashop_variant_row hikashop_variants_table_tbody_tr"> <?php if($this->config->get('thumbnail') && $display['images']){ ?> <td class="hikashop_product_image_row hikashop_variants_table_td" data-label="<?php echo JText::_( 'HIKA_IMAGE' ); ?>"> <?php if (!empty ($variant->images)) { $image = reset($variant->images); $width = $this->config->get('thumbnail_x'); $height = $this->config->get('thumbnail_y'); $this->image->checkSize($width,$height,$image); foreach($variant->images as $image) { ?> <div class="hikashop_variants_table_image_thumb"><?php echo $this->image->display($image->file_path, true, $image->file_name, 'style="margin-top:10px;margin-bottom:10px;display:inline-block;vertical-align:middle"', '', $width, $height); ?></div> <?php } } ?> </td> <?php } if($display['variant_name']){ ?> <td class="hikashop_product_name_row hikashop_variants_table_td" data-label="<?php echo JText::_( 'PRODUCT' ); ?>"> <?php echo $variant->variant_name; ?> </td> <?php } if ($this->config->get('show_code')) { ?> <td class="hikashop_product_code_row hikashop_variants_table_td" data-label="<?php echo JText::_( 'PRODUCT_CODE' ); ?>"><?php echo $variant->product_code; ?></td> <?php } foreach($this->element->main->characteristics as $characteristic) { ?> <td class="hikashop_product_characteristic_row hikashop_product_characteristic_<?php echo $characteristic->characteristic_id; ?>_row hikashop_variants_table_td" data-label="<?php echo $characteristic->characteristic_value; ?>"> <?php if(!empty($characteristic->values)) { foreach($characteristic->values as $k => $value) { foreach($variant->characteristics as $variantCharacteristic) { if($variantCharacteristic->characteristic_id == $value->characteristic_id) { echo $variantCharacteristic->characteristic_value; break 2; } } } } ?> </td> <?php } if($display['product_description']) { ?> <td class="hikashop_product_description_row hikashop_variants_table_td" data-label="<?php echo JText::_( 'HIKA_DESCRIPTION' ); ?>"><?php echo JHTML::_('content.prepare', preg_replace('#<hr *id="system-readmore" */>#i', '', $variant->product_description)); ?></td> <?php } if($this->params->get('show_price') && $display['prices']){ ?> <td class="hikashop_product_price_row hikashop_variants_table_td" data-label="<?php echo JText::_( 'PRICE' ); ?>"> <?php $this->params->set('from_module',1); $this->setLayout('listing_price'); echo $this->loadTemplate(); $this->params->set('from_module',0); ?> </td> <?php } if(!$this->params->get('catalogue')) { ?> <td class="hikashop_product_add_to_cart_row hikashop_variants_table_td"> <?php if ($this->config->get('show_quantity_field') < 2) { ?> <form action="<?php echo hikashop_completeLink('product&task=updatecart'); ?>" method="post" name="hikashop_product_form_<?php echo $this->row->product_id.'_'.$this->params->get('main_div_name'); ?>" enctype="multipart/form-data"> <?php $this->formName = 'hikashop_product_form_'.$this->row->product_id.'_'.$this->params->get('main_div_name'); $this->ajax = 'return hikashopModifyQuantity(\'' . $this->row->product_id . '\',field,\'' . $this->formName . '\',\'cart\');'; $this->setLayout('quantity'); echo $this->loadTemplate(); if($this->config->get('redirect_url_after_add_cart','stay_if_cart') == 'ask_user') { ?> <input type="hidden" name="popup" value="1"/> <?php } ?> <input type="hidden" name="hikashop_cart_type_<?php echo $this->row->product_id.'_0'; ?>" id="hikashop_cart_type_<?php echo $this->row->product_id.'_0'; ?>" value="cart"/> <input type="hidden" name="product_id" value="<?php echo $this->row->product_id; ?>" /> <input type="hidden" name="module_id" value="0" /> <input type="hidden" name="add" value="1"/> <input type="hidden" name="ctrl" value="product"/> <input type="hidden" name="task" value="updatecart"/> <input type="hidden" name="return_url" value="<?php echo urlencode(base64_encode(urldecode($this->redirect_url))); ?>"/> </form> <?php } else { if($this->row->product_quantity == -1 || $this->row->product_quantity > 0) { if(JRequest::getVar('quantitylayout', 'show_default') != 'show_select') { ?> <input id="hikashop_listing_quantity_<?php echo $this->row->product_id;?>" type="text" style="width:40px;" name="data[<?php echo $this->row->product_id;?>]" class="hikashop_listing_quantity_field" value="0" /> <?php } else { if((int)$this->row->product_min_per_order <= 0) $this->row->product_min_per_order = 1; $min_quantity = (int)$this->row->product_min_per_order; if((int)$this->row->product_max_per_order == 0) $max_quantity = $min_quantity * 15; ?> <select id="hikashop_listing_quantity_select_<?php echo $this->row->product_id;?>" class="tochosen" onchange="var qty_field = document.getElementById('hikashop_listing_quantity_<?php echo $this->row->product_id;?>'); qty_field.value = this.value;"> <?php echo '<option value="0" selected="selected">0</option>'; for($j = $min_quantity; $j <= $max_quantity; $j += $min_quantity) { echo '<option value="'.$j.'">'.$j.'</option>'; } ?> </select> <input id="hikashop_listing_quantity_<?php echo $this->row->product_id;?>" type="hidden" name="data[<?php echo $this->row->product_id;?>]" value="0" /> <?php } } else { echo JText::_('NO_STOCK'); } } ?> </td> <?php } ?> </tr> <?php } ?> </tbody> </table> <?php if($this->config->get('show_quantity_field') >= 2) { $this->ajax = 'if(hikashopCheckChangeForm(\'item\',\'hikashop_product_form_variants\')){ return hikashopModifyQuantity(\'\',field,1,\'hikashop_product_form_variants\'); } return false;'; $this->row = new stdClass(); $this->row->prices = array($this->row); $this->row->product_quantity = -1; $this->row->product_min_per_order = 0; $this->row->product_max_per_order = -1; $this->row->product_sale_start = 0; $this->row->product_sale_end = 0; $this->row->prices = array('filler'); $this->params->set('show_quantity_field', 2); $this->setLayout('quantity'); echo $this->loadTemplate(); if(!empty($this->ajax) && $this->config->get('redirect_url_after_add_cart','stay_if_cart') == 'ask_user') { ?> <input type="hidden" name="popup" value="1"/> <?php } ?> <input type="hidden" name="hikashop_cart_type_0" id="hikashop_cart_type_0" value="cart"/> <input type="hidden" name="add" value="1"/> <input type="hidden" name="ctrl" value="product"/> <input type="hidden" name="task" value="updatecart"/> <input type="hidden" name="return_url" value="<?php echo urlencode(base64_encode(urldecode($this->redirect_url)));?>"/> </form> <?php } } ?></div>
where I add that code?
Loredana
10 years 11 months ago #222830 by nicolas
You can add it after the code:
The following user(s) said Thank You: co88agency
10 years 11 months ago - 10 years 11 months ago #222885 by co88agency
I'm sorry... I don't understand...
Can you write me what code I have to add?
(Before I added only "Minimum quantity...")
Thank you and best regards,
Loredana
10 years 11 months ago #222888 by Jerome
Nicolas gave you the place where you need to put your custom content ; as you asked.
10 years 11 months ago #222940 by co88agency
I'm sorry...
I asked you
Loredana
10 years 11 months ago #222943 by nicolas
It depends what you want to display.
If you just want to display the text "minimum quantity per order:50" then just write that text after that piece of code and it will display it.
10 years 10 months ago #226135 by co88agency
Hi!
I'm still here... I have different quantity per different variant... so... I need to write php code:
I write this but it doesn't work...:
<?php $this->params->set('from_module',1); $this->setLayout('listing_price'); echo $this->loadTemplate(); $this->params->set('from_module',0); ?> Minimum quantity per order: <?php echo $this->element->product_min_per_order ?> </td>
Can you help me? Thanks...
Best regards,
Loredana
10 years 10 months ago #226313 by Xavier
Replied by Xavier on topic Minimum quantity per order
To display the value of the variants, you need to use that code instead:
Minimum quantity per order: <?php echo @$variant->product_min_per_order ?>
10 years 10 months ago #226338 by co88agency
Perfect! Now it's all ok, thank you!
Best regards,
Loredana
Time to create page: 0.125 seconds
